For Pro touring, handling modded, lowered cars: New SB Oil Pan -w/pics
Author Topic: For Pro touring, handling modded, lowered cars: New SB Oil Pan -w/pics  (Read 12190 times)
Offline Road_Runner
Re: For Pro touring, handling modded, lowered cars: New SB Oil Pan -w/pics
« Reply #15 on: October 13, 2010 - 08:38:13 PM »
Made in the USA, too!  I'm pretty sure I'll be picking up a big block version for the Roadrunner, and a small block one for the Barracuda.  Neither are going to be road race cars, but the extra capacity, great ground clearance, and baffles just in case are cheap insurance in the long run.  Thanks for helping Milodon with the SB pan.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #16 on: December 13, 2010 - 07:37:01 PM »
I have been on back order for well over a month waiting for my 360 pan.
Anyone getting these lately?
Jackson from Toronto.
« Reply #17 on: December 14, 2010 - 08:28:36 AM »
Same here. When I placed the order in October, that said not until mid November. When I called them in November they said SEMA put that behind the curve on orders and it would be mid December. I haven't called them yet this month, but I'm hoping it is no later than mid January as by then the pan will be the only thing holding up the install of my mill.
Offline boydsdodge
    • Boydsdodge
« Reply #18 on: December 14, 2010 - 06:32:28 PM »
Me too, My machinist/ engine builder wants to run the engine before he sets it free.
He's bugging me to get him the rest of the bottom end parts. (oil pan and pick up)
good to hear that I am not the only one waiting, I was worried my order did not get processed.
Offline autoxcuda
    • Spring Fling
« Reply #19 on: December 16, 2010 - 03:17:09 AM »
I mentioned to them two guys were waiting on 360 pans yesterday.
I think I sort of pushed them to get some out on the market. SEMA, Indy show, PRI all come real close and they have been busy with that stuff.
Here's the TTI clearance to the pan.
« Last Edit: December 16, 2010 - 03:35:36 AM by autoxcuda »
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline SBDave
« Reply #20 on: December 16, 2010 - 01:37:26 PM »
Hey AutoX, are you documenting your engine specs/build anywhere?  I just picked up a 1970's 360 from a Power Wagon that I am going to rebuild.  I still need to tear it apart and find out what condition everything is in.  I don't really have a plan yet.  I might just rebuild it, but I'm looking into stroking it.
But I'll probably end up ordering one of these pans when I get to that point!
thanks
Offline boydsdodge
    • Boydsdodge
« Reply #21 on: December 16, 2010 - 03:53:32 PM »
Thanks Autox for the nudge.
Offline autoxcuda
    • Spring Fling
« Reply #22 on: December 16, 2010 - 04:32:46 PM »
thanks
•SHORT BLOCK: ‘69 340 block, now .030 over. Scat 4" cast crank kit from Indio Motor and Machine.
•BLOCK MODS: Oil passages smoothed and ported to reduce turbulence/cavitation and help flow. Valley smoothed and cleaned up to help oil drain-back. Water jackets/passages meticulously picked clean of rust and slag.
•OIL PUMP: Melling high volume. Passages smoothed and matched to rear main cap.
•HEADS: Edlebrock. Ported, intake and exhaust matched, combustion chambers matched to block,
•VALVE COVERS: Old Cal Custom finned ($20 swap meet) with steel core MP gaskets for good no leak and removable seal
•CAM: Comp 274S soild
•ROCKERS: ???Leaning toward Crane ductile irons or Comp steel rollers.
•INTAKE: Mopar M1 Single plane. Matched and cleaned up. Spread bore flanged filled for square bore carb.
•CARB: Demon Silver Claw 750 cfm advertised. The one they don't/can't make anymore.
•IGNITION: electronic but maybe a nice MSD ??
•OIL PAN: Milodon Road Race/Pro Touring pan developed by Milodon from this project!
•Windage Tray: Milodon with Milodon main stud kit. Windage tray threads cut to fit pan.
•BOLTS AND STUDS: Milodon Made in USA all in house. Heads, Mains, Oil Pan
•WATER PUMP: Milodon
« Last Edit: December 16, 2010 - 04:38:00 PM by autoxcuda »
Spring Fling XXX
April 22 & 23 2016
Offline IMNCARN82
  • LeDZeP
« Reply #23 on: December 27, 2010 - 04:23:10 PM »
Well,I hadn't seen this. Nice job Auto X. It looks great! Personally I swore I'd never buy a milodon again. As the rear seal indents at the top are 1/4" off factory.Might just be this one though.I can tell the difference just in your pics it's better.I'm sure they make quality products. Been around a long time. O.K. I'll consider it.As I really need a new one. And the performance design looks top notch. Didn't get a price...   Thanks!!!R/T
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline autoxcuda
    • Spring Fling
« Reply #24 on: December 27, 2010 - 09:21:30 PM »
Price here:
http://www.milodon.com/oil-pans/road-race-oil-pans.asp
Spring Fling XXX
April 22 & 23 2016
Offline IMNCARN82
  • LeDZeP
« Reply #25 on: December 27, 2010 - 11:37:40 PM »
452.09!?  Yeah,I figured...  :money: big bucks.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #26 on: December 28, 2010 - 10:04:25 AM »
True, but the alternative is you buy a $200 Moroso, Kevco, etc, and then plumb in a $300 accumulator to avoid an oil problems and your suddenly spending more money with more hoses, more engine bay clutter, more chances for oil leaks, and no better oil control.
Offline autoxcuda
    • Spring Fling
« Reply #27 on: December 28, 2010 - 11:48:42 AM »
In a recent Mopar Muscle magazine there was an article on a 427 SB stroker motor built for pro-touring / track day car. That is for Tim Werner's 68 Valiant he runs at Portland International Raceway and other tracks. The Charlies Oil Pan they had that cost around the same as the Milodon did not work. They were losing oil pressure in hard turns.
Now that car has an very experianced driver and a very fast well set up car. But it exposed limits of some of the parts.
This new SB Mopar Milodon pan has the same sump that they have used and developed for years in the SB Chevies and other motors that run in SCCA class competition. Proven piece.
Spring Fling XXX
April 22 & 23 2016
Offline go-fish
« Reply #28 on: December 28, 2010 - 12:34:30 PM »
And for you guys in need of a rear sump pan due to having an aftermarket suspension.......
http://chucker54.stores.yahoo.net/mo360stidrra.html
Offline autoxcuda
    • Spring Fling
« Reply #29 on: December 28, 2010 - 09:45:08 PM »
What does the inside of that pan look like?
Does that pan have side trap doors for side to side loads? How many? Or does it just have fore and aft doors?
There are lots of features done for pro-touring/autocross/road race that add to the cost of the pan above a drag style pan.
Spring Fling XXX
April 22 & 23 2016
