Hey AutoX, are you documenting your engine specs/build anywhere? I just picked up a 1970's 360 from a Power Wagon that I am going to rebuild. I still need to tear it apart and find out what condition everything is in. I don't really have a plan yet. I might just rebuild it, but I'm looking into stroking it.
But I'll probably end up ordering one of these pans when I get to that point!
thanks
Dave
•SHORT BLOCK: ‘69 340 block, now .030 over. Scat 4" cast crank kit from Indio Motor and Machine.
•BLOCK MODS: Oil passages smoothed and ported to reduce turbulence/cavitation and help flow. Valley smoothed and cleaned up to help oil drain-back. Water jackets/passages meticulously picked clean of rust and slag.
•OIL PUMP: Melling high volume. Passages smoothed and matched to rear main cap.
•HEADS: Edlebrock. Ported, intake and exhaust matched, combustion chambers matched to block,
•VALVE COVERS: Old Cal Custom finned ($20 swap meet) with steel core MP gaskets for good no leak and removable seal
•CAM: Comp 274S soild
•ROCKERS: ???Leaning toward Crane ductile irons or Comp steel rollers.
•INTAKE: Mopar M1 Single plane. Matched and cleaned up. Spread bore flanged filled for square bore carb.
•CARB: Demon Silver Claw 750 cfm advertised. The one they don't/can't make anymore.
•IGNITION: electronic but maybe a nice MSD ??
•OIL PAN: Milodon Road Race/Pro Touring pan developed by Milodon from this project!
•Windage Tray: Milodon with Milodon main stud kit. Windage tray threads cut to fit pan.
•BOLTS AND STUDS: Milodon Made in USA all in house. Heads, Mains, Oil Pan
•WATER PUMP: Milodon
