Author Topic: Alternator spacing  (Read 698 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Alternator spacing
« on: October 04, 2010 - 06:47:27 PM »
Hello! I have a 360 that does not have A/C installed. I have the non- A/C  pulleys installed. Will the spacer, that goes between the head and the alternator, be the correct length so the alternator pulley lines up with the water putmp and the crank shaft pulley? I am asking this because I don't want to buy one that isn't the correct size. all the spacers seem to be the same size.
Re: Alternator spacing
« Reply #1 on: October 04, 2010 - 07:41:43 PM »
Measured my 340's spacing is 1.45" total, the spacer is a bit shorter than that, something in the mounting hole on the rear protrudes & makes up the difference.     Clear as mud?.
« Reply #2 on: October 04, 2010 - 09:04:13 PM »
I'll measure the distance and see if the space is around 1 and 3/4. Thanks!
« Reply #3 on: October 04, 2010 - 09:49:05 PM »
1.45" is just under 1 1/2"
