Author Topic: 4-Speed wiring through Firewall for Reverse Light. 70 Challenger  (Read 10242 times)
Offline 4 speed fish
Re: 4-Speed wiring through Firewall for Reverse Light. 70 Challenger
« Reply #15 on: May 20, 2012 - 07:22:53 PM »
Buy a 1 inch recessed plug from RT specialities and drill a small hole in it for the wire.
Offline GranCuda1970
« Reply #16 on: May 22, 2012 - 10:20:01 AM »
Is this wire that goes through the firewall to the tranny sensor part of the underdash wiring harness or is it a separate harness?
« Reply #17 on: May 22, 2012 - 10:53:14 AM »
It is the wire off the reverse harness that connects to the dash reverse light,connect this wire to the reverse light wire after you stick the wire from the harness back thru the firewall hole.
« Reply #18 on: May 22, 2012 - 01:35:31 PM »
Thanks, then it is separate, I think I located a Co. that repops it.
http://www.evanswiring.com/catalog.htm
« Reply #19 on: May 22, 2012 - 01:41:09 PM »
anyone bought from these guys before?
« Reply #20 on: May 22, 2012 - 01:54:37 PM »
Never mind classic industries sells this part.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #21 on: March 18, 2013 - 02:41:07 PM »
  I found that one on my computer. If it can help...
Can anyone tell me what the size of the hole should be for the "Reverse Light" grommet (located between the booster/master cylinder/brake assembly, and the upper-right bulkhead connector hole)?  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
« Reply #22 on: March 18, 2013 - 10:51:56 PM »
Before you drill the hole, buy the harness.
Mega Parts sells them. P/N: 104-DRLW
Then use a digital measuring instrument to check diameter of the grommet.
I'm pretty sure I checked mine and it was 1".
Offline filmsurgeon
« Reply #23 on: March 19, 2013 - 03:00:58 AM »
Yes.  I bought the harness from Evans Wiring.  It has the grommet attached.  I figured I could measure with a digital caliper, as you suggested.  I thought maybe asking here would confirm the grommet size.  The diameter measurement I got is 0.750" (the part of the grommet that would mate with the hole).  So, I guess I'll drill a 3/4" hole.  Thanks for the feedback.
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #24 on: July 31, 2013 - 10:13:15 PM »
I bought the same harness from Evans Wiring.    Thanks for sending the diameter measurement read out.
Getting done this weekend before the challenger goes for replacement disk brakes.   Getting close to being on the road.  I took it for a small spin down the street and back .... without windshields (front and back).    What a buzz .....
Chaps
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
« Reply #26 on: August 01, 2013 - 06:33:35 AM »
The best way to drill a clean hole in sheet metal is to use an electrician sheet metal hole punch , like this , it makes a perfect hole without distroting the metal http://www.amazon.com/Central-91201-Manual-Knockout-Punch/dp/B0012F8GCQ/ref=sr_1_5?s=hi&ie=UTF8&qid=1375353246&sr=1-5&keywords=sheet+metal+hole+punch
« Last Edit: August 01, 2013 - 06:35:43 AM by Chryco Psycho »
