Author Topic: 69 340 stock cam  (Read 8451 times)
Offline iNTP
69 340 stock cam
« on: October 07, 2010 - 09:10:03 PM »
Could anyone please tell me what stock 69 340 cam is?
Im rebuilding my 69 340. The original cam is junk, need to replace. I dont need performace cam right now, just want the stock-replacement one.
I tried summit but no luck.
Thanks so very much.
Re: 69 340 stock cam
« Reply #1 on: October 07, 2010 - 10:47:32 PM »
normal" 340 cam, p/n 2899206, .430 Intake/.444 Exhaust
Bullet Cams should be able to custom grind one for you.
http://www.bulletcams.com/
Offline don340-4
« Reply #2 on: October 07, 2010 - 11:37:09 PM »
 iNTP, I just replaced the lopey cam in my 70 340 with the Mopar factory original resto. got it
 from Year One it is a 268/276  44 O-lap, 114 centerline, lift is 0.429 / 0.444 the part
 #4452782. Year One Part #FD1214
 Now my car runs the way the factory intended it to, very strong & idles perfect with the
 original Carter AVS. Better mpg too. :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline Aussie Challenger
« Reply #3 on: October 08, 2010 - 07:58:35 AM »
Mopar performance purple cam part No. P4452782 comes with lifters and cam lube, can be purchased where ever Purple cams are sold, Bob Mazzolini, Mancini etc.   :cheers:
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #4 on: October 08, 2010 - 08:06:24 AM »
Wouldnt you be better off going with a Voodoo cam that is close to the same spec as the orig?  I know that the tech advances with the years since the orig stuff came out has got to be better then orig spec stuff.
Don
Member Since January 14, 2002
Offline iNTP
« Reply #5 on: October 08, 2010 - 08:01:09 PM »
Thanks a lot folks!
I heard a good things about pre-71 340, I thought I would rebuid my 69 to stock see how it perform. But...
I did some research, it seems to me that alot 340er recommend Comp cam XE268 rather than MP Purple P4452782(stock-replcaement cam).
The XE268:
268-280 duration
224-230 @50
.477-.480 lift
MP P4452782:
268-278
228-235 @50
.429-.444
I have non-experience with choosing Cam. So if anyone here knew/or have tried both of those Cam above, please make a decision for me, which Cam is right?
« Last Edit: October 08, 2010 - 08:52:37 PM by iNTP »
« Reply #6 on: October 11, 2010 - 11:28:55 AM »
I don`t have my catalog handy but I would look into the .904 series Lunati cams , you can get less or similar duration but with more lift
« Reply #7 on: October 12, 2010 - 06:13:23 AM »
Now you are opening a can of worms if you go away from standard which is what you originally asked for, there are some great cams for the 340 and most will liven the motor up for very little variation from stock. If you only use slightly higher lift and mildly more duration you will get away without having to change anything else for good results.   :burnout:
