Author Topic: heater/ A/C box restoration questions  (Read 1423 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: October 07, 2010 - 09:53:47 PM »
 :clueless: :dunno:
Alright, I've managed to get myself this far.
repaired/Restored the HVAC box, check.
Refinished the metal parts, check
Replaced the charcoal foam seals, check
Replaced the gaskets, check.
Tested the heater cores, check..
I have a few questions....
1.) EXACTLY Where does the Dum-Dum caulk go?
2.) where does this seal go?
3.) Is this where this seal goes? (It looks like it went there, as there was evidence from a previous seal) (long slightly thicker seal next to the one I'm holding)
Any help would be appreciated.
Thanks!
Dan
Re: heater/ A/C box restoration questions
« Reply #1 on: October 07, 2010 - 10:10:32 PM »
The dum dum caulk seals the two halves together on final assembly.
I re built a non A/C but not an A/C unit. I think where you show the flapper vent is where the foam glues to the edge.
Offline DMZ73
« Reply #2 on: October 08, 2010 - 06:43:40 AM »
Thanks.... but where does it go?
Dan
Offline Road_Runner
« Reply #3 on: October 08, 2010 - 12:50:21 PM »
What did you do for a guide/instructions on how to do this?  I need to do the same on my 73 with A/C.  Did you use a kit and if so from where?  I think redoing my dash/wiring/AC/Stereo all at once is going to be my big wintertime project.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #4 on: October 08, 2010 - 01:26:39 PM »
Dan
I'm guesssing but perhaps this is where they go.
Does the length match up?
Offline DMZ73
« Reply #5 on: October 08, 2010 - 07:44:45 PM »
Jim,
I got the Kit from DMT technologies. They are awesome!
Highly recommended.
DMT has a website that has the how-to, as a downloadable PDF. I printed it out and used it a s a cheat sheet. JIC. I needed it more than I thought.
Kit costs 70$ and worth every penny.
I found out where it went. It was the flapper seal for the metal plate with two screws.
The Dum-Dum was a little tougher to figure out. :clueless: hope I got it right
The pics shows where it was: The piece with 2 screws in it..
Dan
Offline Road_Runner
« Reply #6 on: October 18, 2010 - 12:11:24 PM »
Jim,
Highly recommended.
Dan
Thanks Dan, I' m ordering my DMT kit today and will start on this as soon as it arrives. Jim
