Wel..I have been fightign a vibration in my cuda. After replacing the engien mounts (which moved the engien forward a good bit) and the trans mount, which resulted in replacing the driveshaft, I developed a vibration at 1500 rpm, bith in drive and in park (360/727).
I spent some time searchin thsi site and moparts for ideas on what to check. One post mentioed to check the bellhousign bolts. after chckign a couple of other small no cost items on my list I found 3 of the 4 bolts were lose...one was finger tight.
I took a quick test drive today and the vibration is gone!!! :burnout:Maybe I can get a few more miles in befor the snow flies.
SO thanks for all the guys that respond to questiosn on this form. I am not sure I would have thought to check those bolts.
So when you are checking stuff, don't forget to check the small things.
Jason
