Author Topic: Z-Bar PG Classics  (Read 2537 times)
Offline challenger_73
Z-Bar PG Classics
« on: October 13, 2010 - 12:32:24 PM »
I recently purchased a brand new z-bar from a member on here and I guess that I should have done a little more homework about PG-Classics before I bought it. Hopefully someone will be able to clarify this for me. PG-Classics sells one Z-Bar for an ebody. I come to find out that there is a difference between a BB Z-Bar and a SB Z-Bar. Could anyone verify this? if so...Do you know which one PG Classics sells? I spoke with Wayne at Brewers and he told me that you can use a SB Z-Bar on a BB but you can't use a BB Z-Bar on a SB. PG Classics could not provide me any support on this. They have no idea. Can anyone help?
challenger_73
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Z-Bar PG Classics
« Reply #1 on: October 13, 2010 - 12:39:57 PM »
what part number did you get, they only have one z-bar for the E-body,   70-74 E #212E, 71-74 B #212B, 66-70 B #212-B70, 66-76 A #212A
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #2 on: October 13, 2010 - 01:23:29 PM »
#212-e is the part that I have. My question is ...will this part work for me? I have a small block 360
challenger_73
sleepychallenger
« Reply #3 on: October 13, 2010 - 01:41:26 PM »
not sure which works with which, but there is a SB and BB one. Alan knows which combos work.
« Reply #4 on: October 13, 2010 - 07:36:14 PM »
What is Alan's Screen name? Can anyone assist with this?  :feedback:
challenger_73
sleepychallenger
« Reply #5 on: October 13, 2010 - 08:14:22 PM »
MOPARAL. Im sure there are more that know too...changin gears and sledgehammer and Chryco Psycho come to mind...
« Reply #6 on: October 13, 2010 - 09:37:17 PM »
The part number is probably right. The length is actually the same, just the levers are in a bit of a different location. BB tq bars are more rare thean the sb bar.  I have 2 extra sb bars around here somewhere. I'd try yours out first, mine is just a UPS truck away.  There is like a 1/2 inch difference
« Reply #7 on: October 13, 2010 - 09:46:44 PM »
appreciate the help thanks much. :thumbsup:
sleepychallenger
« Reply #8 on: October 14, 2010 - 09:37:14 AM »
 :woo: super AL strikes again  :bigsmile:
« Reply #9 on: October 14, 2010 - 10:31:09 AM »
the small block one is slightly longer as the engine is narrower
Offline ShelbyDogg
« Reply #10 on: October 14, 2010 - 10:15:08 PM »
challenger_73
Can you post a picture of your Z-bar? The difference is where the arm is welded on the end. If PG classic only sells one it must be the small block one, determined by your description.  You can get the angled adjuster rod to make it work. Let's see it.
