you need to know if you are using iron or alum heads , you can run close to 10:1 with iron & 11;1 with alum heads requiring different pistons usually unless the alum head have significantly smaller combustion chamber size , you also need to select a cam to work with the powerband, intake , torque converter so everything works together to make it perform at its max potential
