Author Topic: marker bezels  (Read 960 times)
Offline 7samurai
marker bezels
« on: October 21, 2010 - 04:00:09 PM »
try this in the right forum. assembling a 71 cuda with accumulated parts.  the marker bezels have 2 different depths for the reflectors. I assume the deeper one go up front, correct?
Offline dutch
Re: marker bezels
« Reply #1 on: October 21, 2010 - 05:12:03 PM »
the small reflectors on the frontfender markers point to the front and in the rear, they point to the rear
*** Bart ***
Offline dutch
Re: marker bezels
« Reply #2 on: October 21, 2010 - 05:17:21 PM »
I just read your other post on the subject...  :clueless:       do you mean you have 2 different types of sidemarkers?  I can`t remember noticing that... can`t check it for you either, I deleted them on my car.
*** Bart ***
Offline 7samurai
Re: marker bezels
« Reply #3 on: October 21, 2010 - 06:16:37 PM »
I am ok with position of the side marker lights.  The reflector slots are different.  on 2 of them the reflector fits flush all the way across.  on the other 2 the reflector sits inside the bezed about a 1/4 to 3/8 of an inch at the end that faces the middle of the car.  Is it possible that these are not the right bezels?
Offline dutch
Re: marker bezels
« Reply #4 on: October 21, 2010 - 06:40:58 PM »
as far as I know these bezels were used for 70-71 only.  Other years were different and wouldn`t fit your car.
*** Bart ***
Offline moparclown
Re: marker bezels
« Reply #5 on: October 21, 2010 - 06:51:57 PM »
Sounds like you have a pair of Fury side markers,do they have beveled screws in the place of the mounting studs?
Offline 7samurai
Re: marker bezels
« Reply #6 on: October 21, 2010 - 10:20:28 PM »
No, they have the cap screw studs. this is what is puzzling. They fit the cuda fine ant the reflectors and lights fit perfectly.  But the inset for the reflectors is deeper on 2 of them.   One of the deep set ones has "TOP LH" marking on the back and the part numbers are 3403633 & 46430.  Any help???
