My first tranny pull
Author Topic: My first tranny pull  (Read 4107 times)
Offline Katfish
  • 70 Challenger
Re: My first tranny pull
« Reply #15 on: October 25, 2010 - 07:00:30 AM »
Congrats!  So how high did the car have to be?  It doesn't look like you could pull the tranny out from your pic?
Offline tactransman
« Reply #16 on: October 25, 2010 - 07:14:46 AM »
Did you inspect the converter hub and bushing to make sure they were OK?
Terry-tactransman
Union, Mo.
Offline 360FISH
  • BS23H3B567746
« Reply #17 on: October 26, 2010 - 01:49:05 AM »
I measure 18" at the "pinch rail" (not sure that is what the seam is called).  We lowered the tranny off the jack and onto a piece or plywood.  Had to tilt the bell housing down a bit to get clearance.  Would have been a pain if I was doing this alone.  This was ultimately done on the cheap with a floor jack and some wood to stablize (heh) the tranny.   I didn't get the tranny jack because it had been sold 20 minutes before I got to the store... If I did this alone I'd need one.
Yes, and all seemed okay.  We did find a few small pieces of the front seal when we pulled the torque converter.  Appeared to be from the inner part of the seal so I don't know if that wear is going to be a bad omen of something wobbling, out of alignment or what ever...
I have my tranny cooler lines on the way and will hopefully have them for a weekend install ...isn't that what weekends are made for?
Will post back with progress.
Alan
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline 360FISH
  • BS23H3B567746
« Reply #18 on: November 08, 2010 - 01:36:26 AM »
Finally found the fittings needed to install the new cooler lines.
Some pics from the struggle. . .
Must bend you to my will
Beaten into submission
finally lined up.   You get a good shot of the flare fitting doing its work.
at this point I didn’t care about the Teflon monster.  Will trim his tail someday.
I know this car will always be a work in progress, but as I was checking the tranny to see if it was leaking, I noticed I was loosing coolant and now have a new problem.  Looks like a front water pump gasket.  (will post a picture)  :eek4:
I’m really getting a crash course on auto repair.    :working:
Offline 360FISH
  • BS23H3B567746
« Reply #19 on: November 09, 2010 - 01:28:40 AM »
Here is my lovely new challenge...  water pump gasket I presume...  :swear:
