Author Topic: 383 vs. 400 for stroker block??  (Read 9245 times)
Offline 440mike
Re: 383 vs. 400 for stroker block??
« Reply #15 on: November 20, 2010 - 10:59:48 AM »
it is a 1969 383 block which is original from his car and the customer wanted it used.
it was already bored 040 so now it will be 060, and i think he said it will be 438 cubic inchs?
my boss prefers to use the stock reworked forged 440 cranks because we are a shop and its easier, plus they end up much lighter than the ordered chinese cranks which is free power. we do alot of dodges so its easy for us, the kit maybe easier for you ?
it has eagle h beam rods, and diamond flat top forged pistons which work out to 10.4 to 1 for pump gas with the aluminum heads.
it has mildly ported stealth heads by me(its my job) that the customer supplied, comp cams steel rocker arms, and a comp cams solid flat tappet.
the head hardware is changed to comp cams spring etc.
it has an edlebrock rpm intake but i dont know what carb will be used yet on the dyno ?
the boss says it will make between 525hp to 550hp on the Dyno, and he is usually bang on right.
i asked him and he said its ok to put this info here, but the cam i do not know exactly because he gets it custom done, but he said power range is 2500 to 6000rpm with top power at 5500rpm.
he gave me one of those looks, but also said ok to put a dyno sheet when its done, but we are way behind so it will be 2 or 3 more weeks ? i dunno ?
the dyno sheet will have the customer name blacked out.
Offline Road_Runner
« Reply #16 on: November 23, 2010 - 07:01:28 PM »
Thanks again for posting this, and I'm definitely looking forward to you posting the HP & TQ numbers when you get them.  Both my 383 blocks are currently std. bore so I'm hoping not to have to go more than .030 over saving some life in the block.  I much prefer a non-Chinese solution for the stroker setup, but have definitely decided on the imported Stealth heads if I build a stroker B or RB.  I'm not sure what your customer's goals are for his engine, but mine are pretty close to max performance while still maintaing reliability on the street.  So would also be interested where additional HP & TQ could be built into the motor with other options, etc.
Thanks again, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #17 on: November 23, 2010 - 11:02:37 PM »
Thanks again, Jim
jIM, i JUST COPIED THIS OFF OF MOPARTS RACE PARTS FORSALE THINKING YOU MAY BE INTERESTED
Stroker kit and rotating assembly overstock sale:
Low Deck 431ci stroker kit for a 383. 4.280 bore x 3.750 stroke kit includes Diamond Forged Flat top pistons 1.32ch, Diamond Pro-Select moly faced ductile top file fit ring set, RPM H-Beam 6.760 rods .990 pin, RPM Forged 4340 Low Deck 3.750 stroker crank, Federal Mogul rod and main bearings, fully balanced $1650.00 plus shipping.
RB 440 Kit. 4.360 bore x 3.750 stroke kit includes Diamond Forged Flat top pistons, total-seal moly file fit ring set, RPM 6.760 H-Beam rods 1.094 pin, RPM Forged 4340 3.750 Stroke crankshaft, Federal Mogul or Clevite rod and main bearings, fully balanced for $1500.00 plus shipping.
RB 511 Stroker kit: 4.375 bore x 4.250 stroke kit includes Diamond Forged Flat top pistons, total-seal moly file fit ring set, RPM 7.100 H-beam rods .990 pin, RPM Forged 4340 4.250 Stroke crankshaft, Federal Mogul or Clevite rod and main bearings, fully balanced for $1650 plus shipping.
Thanks,
Mike Chenoweth
Chenoweth Speed and Machine
309-266-8084
Full line Parts Supplier!! Give us a call 309-266-8084
SUPERFORMANCE Gaskets!!
Stroker kits!!!
Wilwood Brakes!!
Diamond Pistons!
CNC Machined Mopar Blocks
http://www.chenowethspeedandmachine.com
Offline Road_Runner
« Reply #18 on: November 25, 2010 - 11:40:55 PM »
Those are great prices!  Unfortunately, I just blew my hotrod budget on a rebuilt 69 B Body 4.10 Dana 60 for the Roadrunner.  So the engine is going to have to wait until at least early next year.  That's not necessarily a bad thing since I can't seem to decide which direction to go.
Thanks again, Jim
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #19 on: November 26, 2010 - 05:51:15 AM »
Thanks,
Mike Chenoweth
309-266-8084
That is a SMOKING HOT deal!  Wish that would have been available a year ago!    :misbehaving:
Don
Member Since January 14, 2002
Offline acudanut
« Reply #20 on: December 03, 2010 - 10:52:55 AM »
 If your #1 goal is longevity, just build a 440 or a 383 :2cents:
Stroker kits and machine work will eat your wallet up.
Offline Road_Runner
« Reply #21 on: December 03, 2010 - 01:42:49 PM »
No, Its just that I'm willing to spend the extra $$ to beef up the bottom end, etc. so I'm not back at the engine shop in a year or two.  Mileage-wise, I bet I won't put more than 3k or so miles per year, its more the ability to spin the engine to redline from time to time without worry.
Later, Jim
Offline mopar12372
    • mopartech
« Reply #22 on: December 03, 2010 - 10:19:20 PM »
the 400 is more desireable to build than the 440 / 383
RESTO PICTURES
