Author Topic: 360 head question  (Read 793 times)
Offline alphabuck
    • Pics of my project
360 head question
« on: October 24, 2010 - 12:02:47 PM »
for quite some time ive had a freshly bored 77 360 block and nice heads.  it was always my plan to get a donor motor and then build me a motor.  so a few weeks ago i bought a 360 out of an 83 pickup truck.
last week i acquired another 360 this one out of a 79 ramcharger.  the nice thing about it is its a fresh rebuild with about 20k miles on it. the bad part is its got an air pump and all sorts of emissions junk.
is there a way to plug the little holes under the exhaust ports? it doesnt appear the headers i want to run will do a very good job of covering them up
Offline Challenger6pak
Re: 360 head question
« Reply #1 on: October 24, 2010 - 01:19:38 PM »
You can put bolts in the holes and then grind or break off the bolt heads.  It would be best to take them to a machine shop and have plugs pressed in.  They will leak with the headers if the holes are left open.
Offline vinb
« Reply #2 on: October 24, 2010 - 01:53:57 PM »
You can also drill & tap them to put in set screws flush that way if you need to put it back you vcan do that..
Offline heminut
« Reply #3 on: October 24, 2010 - 08:28:22 PM »
:iagree: That is exactly what I did with the 360 I built for the Dodge van I used to have.
1970 5.7 Hemi Cuda
Offline Aussie Challenger
« Reply #4 on: October 25, 2010 - 06:50:06 AM »
I used brake rivets in my last 360, sealed well, no leaks.
Offline alphabuck
« Reply #5 on: October 26, 2010 - 07:23:54 AM »
thanks for the tips.  i drilled and tapped em and then discovered the set screws i bought were too long.
nothing my grinder didnt fix.  all nice and smooth now  :cheers:
