Author Topic: 440 hp question  (Read 3973 times)
Offline dixiedog
440 hp question
« on: October 25, 2010 - 11:56:58 AM »
I used a 78 year 440, had it rebuilt put a small purple shaft cam and lifters in it, added a holley street dominator intake and Holley doublepumper, aluminum water pump and housing, and headers.  I am not an engine guy, had the work done.  What kind of HP would you think this is set up is producing?  Roughly, I'm just wondering. By the way it sounds great. Thanks, Danny
Re: 440 hp question
« Reply #1 on: October 25, 2010 - 05:25:08 PM »
Not sure about comp height, but A wild guess with small cam and reg heads, 325-375 hp at the flywheel.
Offline Cooter
    • christinecarclub.com
Re: 440 hp question
« Reply #2 on: October 25, 2010 - 08:22:27 PM »
The 1978 440 engine was pig from the factory...(250 HP and VERY low compression, around 7.3:1)..
You never mentioned if you bored it out and installed new pistons when the rebuild was performed. If you used the "Six Pack" replacement, 4 eyebrow pistons then, the compression would be better with the open chamber heads that were on it from the factory...Therefore, the larger "Lumpy" "Purple Shaft" cam would only kill cylinder pressure even further...If it wasn't done with the "Good" pistons, then MY guess would be around 275 HP at the crank...
Offline dixiedog
Re: 440 hp question
« Reply #3 on: October 25, 2010 - 09:16:12 PM »
It is actually a 77 440 but anyway I didn't change the pistons etc.  Thanks guys, Danny
Re: 440 hp question
« Reply #4 on: October 26, 2010 - 06:53:24 AM »
Oh, then it is like what cooter said.  Very low.  I had thought you would of changed pistons
Offline dixiedog
Re: 440 hp question
« Reply #5 on: October 26, 2010 - 12:51:05 PM »
Thanks Al, had I been more in the know I would have.  Thanks again, Danny
Offline Chlngrcrzy
Re: 440 hp question
« Reply #6 on: October 26, 2010 - 08:48:53 PM »
I have a 71  440 with steel crank. What would be the potential for it with a few dollars invested?
Re: 440 hp question
« Reply #7 on: October 27, 2010 - 12:15:15 AM »
lots of potentioal , how long is a piece of string , you can spend to get a lot of performance from a 440 steel crank engine
Offline BB73Challenger
Re: 440 hp question
« Reply #8 on: October 27, 2010 - 12:10:20 PM »
I bet some 915 heads would help... I know a guy selling some ready to go  :naughty:
Jeff from Cleveland, Ohio
Offline Cooter
Re: 440 hp question
« Reply #9 on: October 28, 2010 - 06:34:13 PM »
Sho nuff will, and they's a set a goin' on my 440 In the Kowalski SPecial VERY soon....Thanks again Jeff....
Offline DocMel
Re: 440 hp question
« Reply #10 on: November 04, 2010 - 04:59:34 PM »
What ever HP estimates you might come with at the flywheel, just remember, to the ground HP will be about 20% less
