Author Topic: valve ticking??  (Read 3048 times)
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
valve ticking??
« on: February 06, 2002 - 05:43:07 PM »
ok,i was changing some radiator hose on my 340 cuda. finished the job, started car to check for leaks. While i was waiting i noticed a ticking noise inside the valve cover on the drivers side. Any suggestions here?? i wanna take it to my engine builder bro when i get a chance for his opinion too. This is my daily Driver, so its gotta run good and be dependable. Any clues here, I know its kinda of hard to troubleshoot a sound without actually hearing it for yourselfs.    thanks bro's 8)
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
When you see the Dark Horse...take heed
hell is coming to breakfast......
Re: valve ticking??
« Reply #1 on: February 06, 2002 - 11:23:00 PM »
 The small blocks have a tendancy to bend pushrods you may want to check them ;)
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
Re: valve ticking??
« Reply #2 on: February 08, 2002 - 07:06:32 PM »
i guess ill dispense with the obvious and check if its a solid lift cam?  i had some ticking, but thats only cause the valve lash on my solid lift needed to be adjusted.
Offline Black71Chall
  • If it ain't a mopar it isn't mine!
Re: valve ticking??
« Reply #3 on: February 08, 2002 - 07:34:13 PM »
How many miles does it have on it? i have beat and beat
smallblock mopars and never had a bent pushrod in one but it is never out of the question I have a 170,000
mile 318 in my 83 Dodge ramcharger 4x4  and it run's like a top and im not easy on it either. but would check your pushrods first like Chryco said it would be easiest to do then if all looks good there would replace lifters
and they aren't that expensive. And a piece of cake to do! ;)
Master Of Power And Racing..
More Overall Power And Reliability.
My Own Personal Adrenaline Rush...
"If it doesen't Say MOPAR i don't want it"
Offline Dark Horse
Re: valve ticking??
« Reply #4 on: February 08, 2002 - 07:59:19 PM »
im estimating 122300 mile's. Weird thing i didnt hear the ticking today ??? maybe i just didnt listen for it.
Re: valve ticking??
« Reply #5 on: February 09, 2002 - 04:00:06 AM »
 In the small block the lifters are on a different angle than the pushrods & I have seen them bend often  ;)
Offline heminut
Re: valve ticking??
« Reply #6 on: February 09, 2002 - 08:28:29 AM »
Another thing it could be is an exhaust leak. I've had a leak at the header flange before that sounded just like a lifter ticking!
1970 5.7 Hemi Cuda
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: valve ticking??
« Reply #7 on: February 10, 2002 - 06:49:02 PM »
Or it could be one of those freak things that you will NEVER hear again???
Semper Fi
The Cuda Guy
Member Since January 14, 2002
