Author Topic: Mopar Street Car Specs and E.T.s. 9.99 - faster.......  (Read 7363 times)
Offline Oldschool
  • Member Since 9-05-06
« on: October 29, 2010 - 12:10:58 PM »
Please post your Mopar combo here if your street car runs the 1/4 mile between 9.99 - faster...    :burnout:
Ken  --  In Georgia
Re: Mopar Street Car Specs and E.T.s. 9.99 - faster.......
« Reply #1 on: November 04, 2010 - 04:44:01 PM »
Ken, I believe your a body FB would go here right?
Offline Oldschool
« Reply #2 on: November 05, 2010 - 10:25:57 AM »
Car:  '69 Barracuda - Fastback
Engine:  572 Hemi
Transmission:  727
Rear Diff:  Dana w/ 4.10 gear.
No power adders  --  all motor.   :2thumbs:
Mods:
Vehicle race weight:  3500 lbs.
Fiberglass front fenders, hood, and bumper.
Full 12 point roll cage.  NHRA certified to 8.49 or slower.
Tubbed with Hoosier 31X18.50X15 Quick Time Pro ET DOT slicks
All glass, carpet, door panels and factory dash.
Engine:  UPDATED FOR NEW ENGINE COMBO 03/28/2016
528 HEMI Mega block with stroker crank
Comp Cams custom grind solid roller -- .676 lift intake and .650 exhaust.
Ray Barton crossram intake
2 -- Holley 750 HP carbs
Indy aluminum cylinder heads with roller rocker assemblies.
572 CI Stroker Eagle forged rotating assembly with 11.50 compression pistons.
Milodon oiling system
Custom headers with 3" full exhaust and TTi tips.
Transmission:
3800 Continental converter
Race prepped 727 with reverse valve body and manual shift. Cheetah shifter.
Aluminum driveshaft
Rear Diff:
Dana 60 with Strange internals. Spool with 4.10 ratio.
That is a quick run down of the ole girl.
It runs mid/high 9's on pump gas. 138-142 mph....   :burnout:
Street driven every weekend. It has been down the track twice in 5 years.
« Last Edit: March 28, 2016 - 11:00:34 AM by Oldschool »
Ken  --  In Georgia
« Reply #3 on: November 05, 2010 - 06:55:52 PM »
Hopefully we will see it racing Stroker and Moparal next year at Carlisle! :2thumbs: :stirpot:  HINT HINT :bigsmile:
Offline BIGSHCLUNK
« Reply #4 on: November 05, 2010 - 11:31:24 PM »
I'd love to see Ken give the Beast a good blast!!  :grinyes:  :woohoo:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline StRoKeR
« Reply #5 on: January 17, 2014 - 02:56:03 PM »
Alan as been duckn me fr years just like cudaguy  :poopoke:
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
« Reply #6 on: January 18, 2014 - 07:21:52 AM »
 :roflsmiley: :clapping:. Last I heard your engine was in pieces and you were changing the stroke combo and selling off the extra parts? What the specs on it now? Have you had it out last summer? How does it run?
I REALLY wishing I could have went with an aluminum block for my street build to shave off some more weight.
Post some pictures when you can! I'd love to see what you came up with! :drool: :2thumbs:
Offline Markp
« Reply #7 on: November 21, 2016 - 04:59:45 PM »
Hey guys,
What HP would be needed to break into the 9s? I know there are lots of other factors like weight, suspension, gearing, tires etc. Lets say for arguments sake a Cuda with decent suspension 4.88 gears and around 3400lbs with driver?  Any ideas what type hp would get the car into the 9s? Also what type of money would be needed for that motor?
Thanks,
Mark
1974 Cuda Pro Street Project ???hp
2000 Camaro SS 383 Stroker 550hp
2016 Challenger Hellcat 707hp
Offline marc70challenger
« Reply #8 on: November 21, 2016 - 08:00:16 PM »
Hey guys,
Thanks,
Mark
I found this site.   http://stealth316.com/2-calc-hp-et-mph.htm
As you said.  Lots of factors. For 3300 lbs (car and driver) and optimum (there's the key and challenge) set-up, driver, etc. I'm figuring 750 HP+ for 10.0 ET.  Probably more. As is usual with such predictions.   :burnout:
Edit ... here's another site .... http://www.ajdesigner.com/fl_horsepower_elapsed_time/horsepower_elapsed_time.php   its telling me I would need 672HP .. find that a bit low ... but tells me somewhere around 700-725 is starting goal.  Can always shoot for that NA and add some NOS to get you over ... :2thumbs:
« Last Edit: November 21, 2016 - 08:13:57 PM by marc70challenger »
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Offline Markp
« Reply #9 on: November 24, 2016 - 11:27:58 AM »
Thanks, I was thinking was going to be around the 700hp number. My plan is to get the most reliable engine hp I can afford NA then spray it like you said. So I am hoping I can build a 600-700hp NA motor and then use spray to break me into the 9s. I would love to run 9s NA though. It is hard to build a 9 sec street reliable motor on a budget.
« Last Edit: November 24, 2016 - 11:31:47 AM by Markp »
« Reply #10 on: November 26, 2016 - 04:17:28 PM »
Ya.  :smilielol:   It would take, what, 20k at least. Probably closer 30 k.
Offline 73440
« Reply #11 on: November 26, 2016 - 08:34:30 PM »
I like how the second site includes a paycheck calculator .
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
