Author Topic: radiator coolant line locations  (Read 694 times)
Offline Barracudadan
« on: October 29, 2010 - 08:15:05 PM »
I need to run new coolant lines for my Barracuda.My question is this my car originally was a 6 cyl and still has the original radiator in it,now has a 318 are the locations on the radiator for the coolant lines in the same location as a V-8 radiator.I was looking at a set of lines from Herb`s Parts for a S/B 904 tranny and don`t know if they will bolt right in to my 6 cyl radiator or will I need to do some modifications to the lines to make them fit.
Re: radiator coolant line locations
« Reply #1 on: October 29, 2010 - 08:37:01 PM »
My lines are 10" apart almost if not on center of the car at the radiator.....Clear as Mud?
« Reply #2 on: October 30, 2010 - 09:44:47 AM »
I will check mine I forgot to mention my lines are at the bottom of the radiator and not the side.I`ll assume yours are too.Thanks!
« Reply #3 on: October 30, 2010 - 10:25:36 AM »
Yes all the e-body tranny lines go in at the bottom, there is quite a bit of bend in my OE lines so that it would be possible to locate them an inch or two either way. I don't anticipate that you will have a problem.
