Author Topic: Another wiring question  (Read 939 times)
Offline dixiedog
« on: October 31, 2010 - 11:07:36 PM »
I changed my car to electronic ignition with the 4 post ballost resistor.  My car has a two post resisitor mounted on the wiper motor.  The engine harness had connectors for a 2 post resistor as does the wiper harness.  Why the resistor on the wiper motor?  I also have a wire coming from the firewall box that has been cut.  It is a black wire next to a red wire in the center block.  It looks to me from the diagram that it is the brake warning light wire.  where does it go?  Thanks guys, Danny  (I am learning about this wiring stuff, slowly but surely)
Offline Challenger6pak
Re: Another wiring question
« Reply #1 on: November 01, 2010 - 12:24:48 AM »
The brake warning wire goes to the brake metering valve. Let me know if you need a pic.  I can get one tomorrow.
« Reply #2 on: November 01, 2010 - 02:38:28 AM »
well the wiper motor has a resistor to reduce power for a slower speed on the wiper motor
 any newer ECU for the electronic ign has a 4 pin plug on the EcU so you do not need a dual ballast resistor
Offline dixiedog
« Reply #3 on: November 01, 2010 - 08:03:58 AM »
Yes a picture of the brake metering valve would be great.  Thanks, Danny
« Reply #4 on: November 01, 2010 - 03:39:26 PM »
Here it is, on the drivers side inner fender, roughly below the master cylinder.
Offline dixiedog
« Reply #5 on: November 02, 2010 - 09:03:18 AM »
thanks 6pak, Danny
