Author Topic: How much HP/ tork can I expect from this combo  (Read 1031 times)
Offline SXTY9BEE
« on: November 01, 2010 - 08:08:12 PM »
Hello all, I have a 1969 dodge coronet 440 engine .030 over with Trw flat top pistons stealth heads hooker/comp headers 2 1/2 in. Duel exhaust edelbrock torker single plain intake quick fuel 850-an carb msd dist with 6-al box. Comp cams 305H hydraulic with comp roller rockers. Tci street fighter trans with Tci 3500 stall converter 8 3/4 rear end with 4.56 gears. I'm runnin mickey tompsons outback 31 by 16.5 car is tubbed with 6 point cage and 20 gallon fuel cell. Just replaced the front susp with a kit from just suspensions and just finished with 4 wheel disk upgrade from summit racing. Engine has between 130 and 150 psi when I do comp test. Starts up with 80lbs oil pressure and settles at 60 when hot. I believe the lower end is still stock. What do you think I should see for hp and tork. Thanks
« Last Edit: November 01, 2010 - 09:05:51 PM by SXTY9BEE »
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: How much HP/ tork can I expect from this combo
« Reply #1 on: November 02, 2010 - 01:57:09 AM »
I'll guess around 525hp and 575tq.  Wild guess, good luck.
What did you think of your Stealth heads???
Don
Member Since January 14, 2002
Offline ireland383
« Reply #2 on: November 02, 2010 - 07:17:38 AM »
How far down are the pistons below the deck?  Did you do the comp. test hot or cold?
1971 Plymouth Barracuda
Offline SXTY9BEE
« Reply #3 on: November 02, 2010 - 08:12:21 PM »
I didn't check how far down the piston was when I had the heads off but the comp tests were done when the engine was cold
Offline ireland383
« Reply #4 on: November 04, 2010 - 12:11:28 PM »
Check it hot, then report back. Cranking compression is not a gauge of hp. I had consistent 150-155 across the board on my 383 and have around 400 hp. It's a shame you don't know the piston depth. We can only guess on yours as well 425/475. Has this car been down the track at all?
« Last Edit: November 04, 2010 - 12:15:24 PM by ireland383 »
Offline SXTY9BEE
« Reply #5 on: November 04, 2010 - 08:05:16 PM »
I did run the car years ago in the 1/8 mi. I wanna say it ran around a 7.0 in the mid 80's mph. Same cam with a weiand tunnel ram and 2 600 holleys on it also it was a 3 speed reverse manual trans then to
« Reply #6 on: November 05, 2010 - 05:44:04 AM »
Offline moper
« Reply #7 on: November 09, 2010 - 11:57:33 AM »
Nice build. I'd say in the area or 440-490 depending on the details of the build.
