Author Topic: Conversion kit  (Read 989 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Conversion kit
« on: November 02, 2010 - 11:53:37 AM »
Hello All! I have a challenger with a 360. My dash harness is out of a 73. I wanted to buy a new electronic distributer and I went ahead and bought the conversion kit because it comes with an ecu box and balast resister. I also bought an M+H engine harness that is stock for a 1973. The orange ECU box that came with the kit has 4 prongs.  The original box has 5 prongs. The kit comes with a conntector to splice into your non electric ignition engine harness. My M+H harness is set up for electronic iginition. Here is my question. Will the 1973 engine harness work with the orange ECU box I got with the kit? I'm not sure what the effect is going to be missing the extra prong connector. I have attached a pic of the ECU I have. I am thinking I should have only bought the electronic distributor and bought the 4 prong balast resister and an original style ECU box.
« Last Edit: November 02, 2010 - 12:13:59 PM by Scat Pack Fever »
Offline Roppa440
Re: Conversion kit
« Reply #1 on: November 02, 2010 - 12:43:49 PM »
The missing prong is just a ground connection you don't need. Just make sure the ECU case gets a good ground from the mounting screws.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
Re: Conversion kit
« Reply #2 on: November 02, 2010 - 01:16:40 PM »
Cool! Thanks! Mine was mounted to a bracket that keeps it away from the firewall. I will make sure it is grounded.
Re: Conversion kit
« Reply #3 on: November 02, 2010 - 10:20:40 PM »
the 5th prong is actually a low voltge input , it wasa dropped voltage through the ballast but they moved the resister inside the ECU
Offline CHL2T
  • Handle it, man!
Re: Conversion kit
« Reply #4 on: November 02, 2010 - 11:03:04 PM »
Get a cheap spare ECU, the orange one will fail and leave you stranded.
Ask me how I know  :swear:
Re: Conversion kit
« Reply #5 on: November 03, 2010 - 09:03:59 AM »
Really? Is there a better one to buy??? I don't want to be stranded.
Re: Conversion kit
« Reply #6 on: November 04, 2010 - 11:39:49 PM »
the Chrome box from Mopar is better
Re: Conversion kit
« Reply #7 on: November 05, 2010 - 08:53:47 AM »
I should have bought everything separate. Live and learn I guess.
Re: Conversion kit
« Reply #8 on: November 06, 2010 - 10:25:05 PM »
Mancini is willing to sell the kit & swap out the orange box for chrome
