Author Topic: Starter relay  (Read 1277 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Starter relay
« on: November 02, 2010 - 01:31:57 PM »
Do manual transmission cars have different starter relay's???
Re: Starter relay
« Reply #1 on: November 02, 2010 - 08:10:06 PM »
Not that I'm aware of. They ground differently though. The auto ground through the NSS, the Manual cars through the switch on the clutch pedal.
Re: Starter relay
« Reply #2 on: November 02, 2010 - 10:22:10 PM »
up to 69 the starter relay grounded to the case of the relay , in 70 they moved the ground to the clutch pedal
Re: Starter relay
« Reply #3 on: November 03, 2010 - 09:05:35 AM »
So I take it I need the mechanism that goes on the clutch pedal??? I'm not sure what it's called.
Re: Starter relay
« Reply #4 on: November 03, 2010 - 07:54:50 PM »
Yikes   :scared:
http://www.brewersperformance.com/proddetail.asp?prod=CS2947858
Re: Starter relay
« Reply #5 on: November 03, 2010 - 08:00:30 PM »
That thing is that much???????????? :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :wow: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2: :eek2:
Re: Starter relay
« Reply #6 on: November 03, 2010 - 09:06:54 PM »
I wasn't willing to pay that kind of $ either. My starter relay is just grounded - always.
Offline Aussie Challenger
Re: Starter relay
« Reply #7 on: November 04, 2010 - 07:24:03 AM »
I don't like the idea of having my foot on the clutch when starting a car, make sure it is in neutral first, that is the way I was taught, less wear on clutch throw out bearing, they get noisy quick enough as it is.   :bigsmile:
Re: Starter relay
« Reply #8 on: November 04, 2010 - 08:45:24 AM »
Thanks! You answered my next question. I will do that. Is there a particular way to ground it???
Re: Starter relay
« Reply #9 on: November 04, 2010 - 11:42:48 PM »
just make a pigtail from the spade terminal on the relay out to the body , the mounting screws will usually work fine
Re: Starter relay
« Reply #10 on: November 05, 2010 - 08:52:55 AM »
Cool! Thanks.
