Author Topic: Any circle track racers on here?  (Read 10204 times)
Re: Any circle track racers on here?
« Reply #15 on: May 07, 2011 - 07:27:18 AM »
Starting off the season tonight. Looks like the weather will actually cooperate too?  :faint: :clapping:
Sorry to hear that Bigs.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #16 on: June 14, 2011 - 05:59:30 PM »
Take some pics and let us know which cars are which type.  Thanks.
Don
Member Since January 14, 2002
Offline Aussie Challenger
« Reply #17 on: June 22, 2011 - 06:06:26 AM »
Can somebody explain the "claimer motor" rule I have heard several different versions.   :burnout:
« Reply #18 on: June 22, 2011 - 07:25:50 AM »
We used to have one in the 4 cylinder division but it didn't work. Basically you set an amount say $1000, so the idea was if another racer thought you had spent big bucks on an engine you could pay the money and you owned the engine or the whole car minus racing seat, belts and fuel cell. ( ours was a car claim) You had untill tech inspection at the end of the night to do this. The IDEA is to prevent racers from spending to much money.....
Offline BIGSHCLUNK
« Reply #19 on: June 22, 2011 - 09:01:24 AM »
I havent heard anything like that around here.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #20 on: June 22, 2011 - 12:03:51 PM »
It is a cost containment kind of rule to prevent run away spending on something. Usually it is engines, but I have heard of other items falling in to claimer rules likes shocks and transmissions and, like Brad pointed out, entire cars. IMCA is the biggest purveyor of claimer rules, theirs are on engines.
The idea is if someone is spending significantly more than anybody else on an engine to out power the field, then they run the risk of loosing it to a claim. There are usually some pretty stringent rules to execute claims and it is not a free for all buy fest. Typically, only the top three finishers in the main event can be claimed, the person making the claim had to finish the main event somewhere behind those three, you can claim one of those three engines only, you can only claim once a weekend, claims do not include ignition, exhaust, or carburation. Claim values can range from a few hundred to a grand or more depending on the organization and/or track.
If your going to claim an engine, then you better be darn sure that they are out motoring you. Typically in claimer classes, motors are one step above junk and most the money is spent on items you won't loose, which is the premise on cost containment of the program. When I ran these classes we would typically buy junk yard core motors for $150, hone them like mad to reduce taper, slap in the tallest compression height cast pistons we could find ($100 or so-usually swap meet finds), use some JC Whitney seals all rings ($25), new bearings ($50) a summit or Lunati cam kit ($100) and a gasket set ($50). There you go, running engine for under $500, small block chevy, of course, and it might last 4-6 weeks before needing new bearings. We never finished high enough in any main to get claimed, but had people tell us if we did, they would have claimed us. I attribute that to the fact that we could keep up with the next class above us in the straights, but were still dialing in our corner performance. The only trick in our engines was compression. We didn't have a rule against how much we could run, so we always tried to get as much as possible.
We did spend some bucks on a blueprinted distributor and some custom carb work.
Offline nitr0_fish
  • Newbie
« Reply #21 on: July 09, 2011 - 06:57:13 PM »
I used to race circle track.
Here is a pic of my last car & my wife's car:
(Sorry, neither one is an E body)
Offline wagesofsin
  • just a sinner
« Reply #22 on: July 10, 2011 - 08:07:14 PM »
that yeller 95 car is a pal of mines, clint roberts.
ok, ill go now... :roflsmiley:
Offline djr71
« Reply #23 on: July 12, 2011 - 08:28:58 PM »
I am a circle track guy. I started at Seekonk Speedway, worked in the Busch North Series, Busch Series, Crafstman Trucks, Cup and PASS tour.
Only ran Dodges in the truck and cup series. Also did  a ton of SCCA autocrosses. I tried drag racing it was fun but waiting hours betwenn runs was too boring.
« Reply #24 on: July 12, 2011 - 10:09:19 PM »
Cool!  :cooldancing:   Got any pictures?
Offline djr71
« Reply #25 on: July 13, 2011 - 10:23:22 AM »
I have a ton of pictures I took the first pic at Louden and the second at Daytona. I helped Morgan out for 5 years in the Cup Series and the Truck Series
« Reply #26 on: July 13, 2011 - 10:48:38 AM »
Sweet! :2thumbs:
Offline dude95
  • Newbie
« Reply #27 on: August 14, 2011 - 02:57:01 PM »
Cool pictures! I'll pass them along to my buddy that's building a new Challenger stock car using a Cuda chassis that was a stock car before he bought it. It's pretty cool, close to a Chrysler kit car. It's stripped down to the roll cage/chassis now with just a roof on it.
hey, that yellow #95 is mine and a buddies circle track car.. we actually have 2 on them.. cool to see other pics of it..
