Author Topic: Column shifter arm/handle  (Read 593 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: November 02, 2010 - 11:14:34 PM »
The shifter arm on my column shift car needs to be rechromed since it is peeling. What I don't know is how to remove the black plastic handle on the end. Is it screwed  on in the center or pressed or glued on? I hesitate to try and remove it because I don't want to destroy it in the process.
Thoughts?
Re: Column shifter arm/handle
« Reply #1 on: November 11, 2010 - 07:46:14 PM »
the plastic will not come off , you can polish the arm with fine steel wool or get a different one in better condition
Offline peterro
    • The Pistonhead
« Reply #2 on: November 13, 2010 - 09:29:14 PM »
Ok thanks. I guess it'll have to be a different one then since the chrome is peeling off and would need to be replaced.
Offline quapman
    • Auto-Grip on Facebook
« Reply #3 on: November 13, 2010 - 09:54:54 PM »
Year One used to sell NOS auto column plastic shifter knobs, so apparently the two pieces come apart.
Offline peterro
    • The Pistonhead
« Reply #4 on: November 26, 2010 - 05:31:17 PM »
Does anyone know what the part number would be? Maybe someone makes replacements.
