Author Topic: 8 3/4 rebuild ?  (Read 1260 times)
Offline rb70
8 3/4 rebuild ?
« on: November 03, 2010 - 07:32:34 PM »
Is there a place where I can get a rebuild kit or a service that rebuilds the rearend?
Should I just do the chunk or should I do everything?
Car sat for 4 years and makes a loud clunk when it goes into gear.  I am going to replace the joints, but was wondering what to do about the rearend.
Re: 8 3/4 rebuild ?
« Reply #1 on: November 03, 2010 - 10:41:33 PM »
Did you by chance see this article?
http://www.moparmusclemagazine.com/techarticles/drivetrain/5148_custom_rear_end_install/index.html
At the very last page it gives 3 references. Many members here and on Moparts contact Drdiff.com.
http://www.doctordiff.com/
He does Mopars
Offline Katfish
  • 70 Challenger
Re: 8 3/4 rebuild ?
« Reply #2 on: November 03, 2010 - 11:03:20 PM »
I'd check the u-joints before you tear it apart.  Loud clunk sounds doesn't seem like a gear problem.
Offline rb70
Re: 8 3/4 rebuild ?
« Reply #3 on: November 03, 2010 - 11:56:07 PM »
As stated, I am replacing the u-joints, but the car sitting for so long worries me.  I am going to have it out to go over the underbody and figured it was the perfect time to rebuild the unit.
Re: 8 3/4 rebuild ?
« Reply #4 on: November 04, 2010 - 02:35:23 AM »
If a ring and pinion set are in the plans to be replaced, I would recommend Richmond ring and gear. One of the best.
Offline rb70
Re: 8 3/4 rebuild ?
« Reply #5 on: November 04, 2010 - 07:20:06 PM »
Any place with good service and price?
Re: 8 3/4 rebuild ?
« Reply #6 on: November 04, 2010 - 07:43:45 PM »
Richmond if you are doing the rebuild.
Call them.
http://www.richmondgear.com/07Apdfs/page5.pdf
Re: 8 3/4 rebuild ?
« Reply #7 on: November 04, 2010 - 11:44:21 PM »
Dr Diff is good too
