Author Topic: How to shave a second? 440  (Read 6674 times)
Offline boxfox
« on: November 04, 2010 - 10:17:46 PM »
I have a 72 Challenger with a 77 440 engine, 727 3 speed transmission, 2.76 gears currently and thinking about moving up to 3.23, want to retain highway driveability. How fast can I get with the 3.23? can I make it into the low 13's with that?
I assume I'm running a high 14 by now...I'd like to make it into the 13's, what do I need to do?
The only thing I haven't really worked on on the car is the engine...
I'm still fairly new to the motor world so if you say stroking the engine would be good, I have no idea what that is...I'd rather not cut a hole through the hood yet so supercharge might be out of the question..might not be...
I'm mostly looking for suggestions..
Re: How to shave a second? 440
« Reply #1 on: November 05, 2010 - 12:18:11 AM »
Here's a helpful tool to help self educate yourself what changes will create what kind of results. Look thru it all and plug in different factors and after a while you will be able to get a better idea on what results will occur by what changes if you added.
http://www.golenengineservice.com/html/calculators.html
Offline boxfox
« Reply #2 on: November 05, 2010 - 11:25:16 AM »
Thanks Topcat
Offline mojavered
  • Someday!
« Reply #3 on: November 05, 2010 - 11:25:40 AM »
Thanks for the link Topcat.  I had seen it before but could not find it a while back when I wanted it.
Jason
Offline boxfox
« Reply #4 on: November 05, 2010 - 11:35:38 AM »
So how far would I be able to take a 3.23 sure grip on the 1/4 mile?
« Reply #5 on: November 05, 2010 - 11:54:48 AM »
Well that all depends. If you had 900 HP and 800 Ft lb Torque and you were running tires on a 14 x 6" you would be pretty fun to watch.  :lol: j/k.
 :2cents: I would at least start at 3:55 with some decent tire width and up if you plan track times.
« Reply #6 on: November 05, 2010 - 11:58:49 AM »
I hear stories of bracket racers that drive their Mopar to the track with a 8 3/4, 3.23, then switch to a 3.91 at the track, make a few passes. Then switch it back to 3.23 then go back home.
Offline boxfox
« Reply #7 on: November 05, 2010 - 12:08:29 PM »
Sounds abit extreme, I'm mostly wondering if 3.23 could get me into the low to mid 13's
Offline Cooter
    • christinecarclub.com
« Reply #8 on: November 05, 2010 - 01:06:52 PM »
You didn't mention if you had rebuilt that '77 440 or not..I'm gonna assume not really...You could shave 1 full second off your ET just by rebuilding it with good parts like 10.0:1 piston's and a camshaft upgrade...A stock '77 440, is only around 250 HP at best...Being your running 14's now, I'd think it has at least 9.0:1 compression..3.55 Gear will also improve ET as well...
Offline boxfox
« Reply #9 on: November 05, 2010 - 01:29:00 PM »
Negative on that rebuild, I have not touched the engine.  How much do you think parts like that might cost me. And whats good to buy?
« Reply #10 on: November 05, 2010 - 01:53:01 PM »
I used to drag race an 82 Cordoba.  It was 3600 lbs but I can't remember if that was with me in it or not.  It was completely stripped and that was as light as I could get it.   I ran a very mild 360, 904 with a 10" 3500 stall convertor, 4.10's and 29" slicks.  I ran a best of 12.71 @ 106mph.
Before I added the 4.10's and slicks, I was running 3.23's and 235-60-15 BFG drag radials.  My best time was  13.55 @ 89mph.  That was with a mild 360.  You should be able to run mid 13's with a 440 no problem.  With the same mods to your 440 that I did to the 360...and the 3.23 gears...you should be in the very low 13's or on a good day, possiblly high 12's.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #11 on: November 05, 2010 - 04:49:53 PM »
I think that the late 70's 440's were about 8.5:1 comp.  If you switched to a thin shim type head gasket you might get to 9.0:1 which is still good for pump gas and iron heads.
Gasket Match Porting of your heads and intake will improve flow.
Get a larger cam
http://www.lunatipower.com/Product.aspx?id=1579&gid=287
Intake Manifold
http://www.summitracing.com/parts/EDL-7193/
New Carb
http://www.summitracing.com/parts/PRO-67201/
Id say this set of parts should shave a second of your time slip.
Also look at removing weight to help get the car moving faster.
Disclaimer: I by no means am a engine expert, these recommendations are the things I have picked up here reading similar posts, I have no metric to base these parts off of.
Don
Member Since January 14, 2002
Offline Cooter
« Reply #12 on: November 05, 2010 - 07:58:58 PM »
The '77 "HP" "Cop" motors were close to 8.5:1..The everyday 440 was closer to around 7.7:1 in '77-'78 thanks to the ever popular EPA...
« Reply #13 on: November 05, 2010 - 08:44:44 PM »
Yep, the late 70's 440's were rated at 245 HP.   :faint:
Offline boxfox
« Reply #14 on: November 05, 2010 - 10:31:58 PM »
I've already got that eldebrock performer RPM intake actually, engine sounds like it might have a cam already. Running on a 670 CFM carburetor, I know I need atleast a 750 CFM, should I get a double pumper or is vacuum secondary going to be any different?
What do I need to do to up the compression, and where do I want it to be?
And you said that the thin shim type head gasket would help? Does Summit racing offer those and how do they increase compression exactly?
