Author Topic: I need help with cleaning primer from the gun What to use  (Read 938 times)
Offline AZDAN
« on: November 08, 2010 - 10:19:09 PM »
I shot some 2K high build primer, tried to clean the gun and I can not get it clean enough. I tried reducer, then brush cleaner which it is soaking in right now. Should I go buy some acetone or MEK. Suggestion s please. This the primer I used KFP - 2K HIGH BUILD ISO-FREE PRIMER
Offline Cuda Cody
  • Vancouver, WA
Re: I need help with cleaning primer from the gun What to use
« Reply #1 on: November 08, 2010 - 11:35:04 PM »
Your local automotive paint store will have gun cleaner / solvent.  Works real good, but you don't want to use it all the time because it's hard on the gaskets in the gun, however it will clean your gun nicely.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #2 on: November 09, 2010 - 03:20:41 AM »
lacquer thinner might work.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline dutch
« Reply #3 on: November 09, 2010 - 05:28:53 PM »
methylenechloride / dichloromethane will clean it up. Not sure if it`s available there  :dunno:  make sure you don`t breathe that crap  :eek4:
*** Bart ***
Offline Cuda Cody
  • Vancouver, WA
« Reply #4 on: November 09, 2010 - 08:39:19 PM »
The stuff you want is called "Naked Gun".
Offline acudanut
« Reply #5 on: November 09, 2010 - 08:47:53 PM »
Works great, However it may be too late...If you spray nozels/jets jets have that primer still in there.   :2cents:
Offline 72bluNblu
« Reply #6 on: November 10, 2010 - 01:12:08 AM »
I've always used acetone. Not sure if its the best, but it's always worked.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #7 on: November 10, 2010 - 05:59:02 PM »
Laquer thinner if the paint isn`t hardened up,otherwise you might need to tear it down and use paint stripper.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
