Author Topic: 340 Oil Pressure Sender Location ??  (Read 3152 times)
Offline 72 Cuda Replica
« on: November 09, 2010 - 06:36:40 PM »
What is the factory location of the sender unit on a 340?  The guy that built my car put in an aftermarket gage using plastic tubing into the passenger compartment.  The fitting for the compression nut goes into a 1/8" NPT hole at the back of the passenger side head.  Same place for the factory sender? The tubing broke at the fitting.  What a mess.   :swear:  I want to go to an electrical gage - either the rally gage or an aftermarket under the dash.  I was planning to do this anyway.   :violin:
Also, is the sender unit the same whether the car had idiot light or gage?
'72 Cuda Repli-mod-custom 340 with cam, headers, 10:1 pistons, ported factory heads, manifold and carb, hi-flow custom (loud) exhaust
A727, 3.55 Sure Grip
'11 Ranger 4x4
'03 Grand Marquis
'08 Sportster Stage 1
Offline the_engineers
Re: 340 Oil Pressure Sender Location ??
« Reply #1 on: November 09, 2010 - 06:39:17 PM »
Next to the distributor there is an 1/8" NPT hole.  That's where it goes.
Pretty sure the sender is different for Rallye vs. non.
If you go aftermarket, it'll come with (or you'll have to buy separately) a specific sending unit.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #2 on: November 10, 2010 - 04:48:30 AM »
I have an oil fed gauge that I installed in 1974.  It is located at the rear of engine intake manifold, next to distributor as Brooks said in the above post.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
