Author Topic: Headers Vs. Exhaust Manifolds  (Read 9035 times)
Offline BB 70 Challenger
    • Restored Sports Cars
Re: Headers Vs. Exhaust Manifolds
« Reply #15 on: December 02, 2010 - 02:26:40 AM »
A friend of mine and a regular member here had his 489 cid (4.28" x 4.25") B Wedge dynoed both with the stock Magnum cast iron exhaust manifolds and also with headers. The engine is a very much stock looking pump gas engine.
The power numbers were:
- stock exhaust manifolds + full exhaust: 458hp/5000rpm & 520t.lbs/3700rpm torque http://3.bp.blogspot.com/_1utFs2uOvMs/SbaF6q1AD-I/AAAAAAAACj0/oq-LLmIiTEc/s1600-h/valusarjat.jpg
- 1 3/4-3" headers + full exhaust:          484hp/5100rpm & 531ft.lbs/3400rpm torque http://4.bp.blogspot.com/_1utFs2uOvMs/SbaJAY768CI/AAAAAAAACkE/amYKdT1oH2g/s1600-h/peltisarjat.jpg
So, the difference in power is something like less than 30hp and about 10ft.lbs torque in peak numbers. That is not too much? I understand that in even bigger and more powerful engine the difference is likely more, though.
« Last Edit: December 02, 2010 - 02:37:22 AM by BB 70 Challenger »
Offline Aussie Challenger
« Reply #16 on: December 02, 2010 - 04:30:50 AM »
MOPAR did do some home work on the cast iron manifolds but headers usually give more, notice that peak torque is lower and peak HP slightly higher, sometimes a little tweaking of the jets is needed when going to headers also which can give slightly bigger numbers.
Offline Marquis_Rex
  • Takes a Mopar to Catch a Mopar...
    • auto-scape
« Reply #17 on: December 07, 2010 - 11:35:28 AM »
The above shows a dyno powercurve under taken at Chrsyler Engineering in the mid sixties during the development of the original Gen 2 Hemi engine. The power curve is shown with and without tuned length headers (vs C body and B Body style log manifolds). Appologies- that the engine rpm axis has been cut off- but it should go from 1200 rpm to 6400 rpm which most of the original testing was done with. As you can see this changes makes quite a difference in power AND torque. A much bigger difference than some of the modern 32 valve V8 engines I've been involved with.
1970 Dodge Challenger 440 R/T
1995 Porsche 911 turbo (993)
1982 BMW 323i "E21"
1985 BMW M635CSi "E24"
2003 Dodge Ram 1500 4x4
1971 Jaguar XJ6 series 1
2000 Jaguar "X308" XJR
1993 Mercedes 400E
1964 MCI MC-5 coach 'RV'
