after 40 years there could be a bunch of reasons you have a different set up in there , if the engine was rebuilt it may be internally balanced or it could be the wrong flywheel / Balance for the engine . the 11" disc is the same for the 10.98 " 130 tooth system or the 11" 143 tooth , just the pressure plate is different , there is no reason what you have will not work as long as the starter lines up . but there are new flywheels & belhousing available if you want to swap to the the 130 tooth system
