yes, there will be promax plates installed, so no issues then. Thanks for the verification
just for the curiosity... I´m having correct center carb for my T/A with manual transmission but what´s the difference between the center carbs 4791 (for manual) and 4792 (for automatic)?
Probably the linkage and jets differ slightly.
Jetting tips for the 340+6If a completely stock system try increasing the jet size on the centre carb up to #63 each side (manual trans) or #64 (automatic) but leave the outer carbs alone.
If a stock Aluminum Edelbrock Manifold;
----------------------------------Throttle Side--------- Diaphragm Side
Front Carburetor MMO------------- .086----------------------.073
Center Carburetor Jet-------------- #63---------------------- #63
PVCR--------------------------------- .046--------------------- .046
Rear Carburetor MMO--------------- .086-------------------- .073
Same as above but with heat cross-over blocked;
------------------------------------Throttle Side-------- Diaphragm Side
Front Carburetor MMO-------------- .086--------------------- .073
Center Carburetor Jet-------------- #64---------------------- #64
PVCR--------------------------------- .046---------------------- .046
Rear Carburetor MMO----------------.086--------------------- .073
