You really wanna know what's involved on your first "test" pass on the button to tune the kit?
1. Install complete stand alone, fuel system, with Holley "Blue/Black pump and regulator with around 1/2" line all the way to front of car.
2. Install the Nitrous spray bar under your carb with supplied extra length studs and gaskets. It is marked "Up" as NOT to install upside down...You DO NOT Want to do this....
3. Wire the Solenoids for N20 and Fuel.
4. Wire in the ARM switch, any Safetly switches, and Bang button.
5. "test" fire EMPTY system to make sure BOTH FUEL AND N20 SOLENOIDS ARE FIRING TOGETHER!
6. Mount Bottle in trunk with supplied bracketry.
7. Run Nitrous braided line to the Nitrous solenoid and hook up to solenoid..
8. Install a Nitrous Guage on the bottle (Sold seperately) to Monitor bottle pressure..Optimum should be around 900-1000 PSI when ready to spray...
9. Buy bottle heater sold seperately.
10. Finally get bottle filled with N20..
11. Install Seperate Fuel pressure Guage (Sold seperately) to monitor fuel pressure at the solenoid for Fuel..
12. Install supplied Jets for around 150 HP shot..
13. Hold engine RPM up around 2000, and "Test" fire kit with engine running by "blipping", or "Tapping" the button..(This is also how I purge my kit). You should hear the engine rev REALLY quickly...Kinda like a Race Engine does with really big roller cam..
14. Finally, you are ready to set your timing. If at 14 degrees initial (Base), you need to back off around 6 degrees for a baseline.
15. Ok, you are now ready to give a "trail" pass on the track preferrably, but I know it most likely be on a back road somewhere.
16. Once you've done about a 6 second blast, as soon as you let off the button, you shut down the engine and pull over on the side of the road and pull ALL 8 PLUGS to see how they are burning...you should see a nice "Turkey Turd" brown color...IF you see WHITE specs, then it's too lean...(Not enough fuel pressure/volume.
17. Reinstall ALL 8 plugs, and up the fuel pressure 3 lbs and do the same thing AGAIN, until you reach the "Brown" color on the plugs. Then, and ONLY THEN are you ready to go get 'em...
18. IF you "up the anti" and jump the HP level, repeat steps 14-17 AGAIN....
Remember, for every time you Spray your car, the bottle pressure goes down..Kinda like a hairspray can when it turns cold after spraying it? You will need to RE-HEAT the bottle in order to keep the bottle pressure at a constant 900-1000 PSI for your next pass.
