Author Topic: Non Ebody trans fluid leak  (Read 755 times)
Offline the yam
« on: November 11, 2010 - 06:14:56 PM »
I know this is similar to a previous post but since I am leaking trans fluid while daily driving, I think its a different issue. I have a 2005 Jeep Liberty 3.7L that is leaking trans fluid where the prop shaft slides into the transmission. In the picture, you can see some fluid pooling on the black rubber piece. I assume there is some type of seal or gasket (possibly the red piece in the picture?) that needs to be replaced but I am not exactly sure what part I will need or how to replace it. Could anyone point me in the right direction?
70 Challenger 440
Offline GoodysGotaCuda
Re: Non Ebody trans fluid leak
« Reply #1 on: November 11, 2010 - 06:33:44 PM »
That red ring is holding in the output shaft seal. That seal that you are seeing in the picture is likely just a dust boot for the 'real' seal that is behind it. Basically need to remove the driveshaft, pop the seal (red ring) out and tap a new seal in.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline the yam
« Reply #2 on: November 12, 2010 - 01:58:57 PM »
Thanks for the quick response.
Do you know if any special tools would be needed or is it something I could do myself? Would adding transmission stop leak fluid be worth a shot?
70 Challenger 440
« Reply #3 on: November 12, 2010 - 07:07:57 PM »
It shouldn't be a very difficult repair. A seal remover, from any parts store would help. Stop leak is not going to help
1976 Dodge Warlock
Offline tactransman
« Reply #4 on: November 13, 2010 - 10:58:28 PM »
Make sure the bushing is not worn out also. Seems like they are gonna be bad about wearing the rear bushing out.
Terry-tactransman
Union, Mo.
