Author Topic: 70 Cuda turn signal  (Read 1290 times)
Offline rb70
70 Cuda turn signal
« on: November 11, 2010 - 06:53:37 PM »
Got my car with no turn signal arm, so I have a few questions.
I got the 70 Plymouth service manual on CD and it is missing a few pages.
So is there something that attaches the turn signal arm to the cam?
I got a new cam harness, do I just have to remove the cylinder lock guard(for a lack of a better term) to get the old harness off and install the new one?
TIA
Re: 70 Cuda turn signal
« Reply #1 on: November 11, 2010 - 06:58:23 PM »
A long screw hooks the arm to the switch cam.   If you master pulling the crush can ok, I am betting it will be a no brainer for you   (with the screw).  Get the right switch tho. 70 is different from the rest
Offline rb70
« Reply #2 on: November 11, 2010 - 07:23:38 PM »
Thanks, I see where it connects now.
Any tips on getting the crush can off?
« Reply #3 on: November 11, 2010 - 07:33:36 PM »
That's not an easy job if it has never been removed before. You will need a steering wheel puller.
Offline ShelbyDogg
« Reply #4 on: November 12, 2010 - 03:45:51 PM »
I use a harmonic balancer puller and get 2 long bolts at the harware store to attach it to the splined coupler at the bottom. Do not use the 3 bolts where the wheel mounts or you will distort your crush can.   Most "cheap" tools stores have the puller for around $5.  Do not try to pull your wheel and can off while hammering on the threaded shaft. It might come off but will destroy the threads.
Offline drewcrane
« Reply #5 on: November 12, 2010 - 03:52:39 PM »
I just happen to have a pic from a previous project, hope this helps
Offline Katfish
  • 70 Challenger
« Reply #6 on: November 12, 2010 - 04:27:03 PM »
Good pic, is that  a speciality puller?
Offline drewcrane
« Reply #7 on: November 12, 2010 - 06:04:51 PM »
Not really it's just from checkers , it comes in a set, and that one worked the best,
be patient ,make sure the main center bolt is in line with the shaft,
 and it is tight but it comes out with some elbow grease , i used an impact wrench and it comes off fast and easy :bigsmile:
Offline 4Cruizn
  • HEMI FISH
« Reply #8 on: November 13, 2010 - 01:36:31 AM »
Yep . . . same one I used!   :2thumbs:
Offline rb70
« Reply #9 on: November 14, 2010 - 04:59:51 PM »
Where did you get yours?
I cannot find one w/long enough bolts.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: November 14, 2010 - 05:32:46 PM »
any standard puller will work, as for the bolts go to your local hardware store
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline rb70
« Reply #11 on: November 14, 2010 - 07:37:59 PM »
No, not any will work.
I have gotten 2 and on both sets, the bolts were to short.
Offline ShelbyDogg
« Reply #12 on: November 14, 2010 - 07:40:28 PM »
WOW!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #13 on: November 15, 2010 - 12:25:03 PM »
 :nono: puller isnt the problem its the bolt length. these are pulley/damper pullers NOT column tools.  none of the pullers will come with the length needed . that is why i stated that you need to go to a hardware store and purchase the longer bolts.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
