Author Topic: 70 Cuda starter relay wiring  (Read 10629 times)
Offline rb70
« on: November 11, 2010 - 11:13:49 PM »
My harness has been hacked to death, does anyone have a drawing or better yet pics of the wiring from the firewall to the relay?
I have a yellow wire coming throuh the firewall to the relay and from what I can tell from a wiring diagram. It should be a red wire with a fusible link going to the relay from the harness.
Re: 70 Cuda starter relay wiring
« Reply #1 on: November 12, 2010 - 07:08:49 AM »
You should have both yellow & red-w/fusible link ....this pic is from my '73 but should work for a '70
Offline rb70
« Reply #2 on: November 12, 2010 - 05:36:28 PM »
Thanks, that was exactly what I needed.
Offline jdavis2169
« Reply #3 on: September 13, 2012 - 07:14:15 AM »
sorry to kick up an old post but where does the ground on the relay come from. I put new harnesses in my 70 challenger but dont see this plug anywhere. 440 auto.
« Reply #4 on: September 13, 2012 - 07:57:19 AM »
The ground comes from being in contact with the body of the car.
Offline jdavis2169
« Reply #5 on: September 13, 2012 - 08:07:32 AM »
Sorry meant the wire labeled ground from interloc trans. That point i don't have a connector. I put new harnesses in my car and am not getting power at the ignition switch.
Offline JayBee
« Reply #6 on: September 13, 2012 - 09:39:57 AM »
Just checked my car. On mine it's a brown wire with a yellow tracer that comes from the NSS harness. It's the plug on the bottom left of the bulkhead connector looking at the firewall from the front.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #7 on: September 13, 2012 - 09:52:08 AM »
There is a separate harness for the interlock, one if automatic, a different one if manual.
 http://www.evanswiring.com/catalog.htm
Offline jdavis2169
« Reply #8 on: September 13, 2012 - 10:20:43 AM »
Thanks guys just ordered that harness the other day. That explains quite a bit for me.
« Reply #9 on: September 13, 2012 - 11:44:07 AM »
The ground for the relay to operate is from the transmission if auto, clutch switch if manual.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: September 13, 2012 - 01:25:37 PM »
I'm going to go out on a limb here but I believe not many 4 speed folks have this hooked up.
Makes more sense with an Auto.
B
« Reply #11 on: September 13, 2012 - 05:26:48 PM »
Well, a repo clutch switch is about $350. So you might be right....
