Author Topic: 70 Cuda cuts out after it gets warm  (Read 851 times)
Offline V02Barracuda
« on: November 12, 2010 - 09:33:44 AM »
Hello,
My problem is definitely electrical.  I replaced the engine wiring harness about a week ago on my 70 Barracuda.  Seemed like a quality harness.  Drove the car with no problems.  2 nights ago I decided to go for a ride and the car cut out at the bottom of my street.  I restarted it and it fired right up, ran for 5 seconds and died again.  This happened a few times.  Luckily, I was able to keep it running, turned it around and limped it home.  It did die 2 more times but I made it home.
I replaced the distributor, coil, ballast and the ECU one by one.  After replacing each one the car would still die after idling for a few minutes.  It will idle in my garage (cuz there is no way in hell I'm gonna drive it now) and it will cut out.
I was reading another thread and someone piped in and said that he put a new wire harness and experienced the same problem.
Are there a string of bad harnesses out there?
Thank you to anyone who can help.
Re: 70 Cuda cuts out after it gets warm
« Reply #1 on: November 12, 2010 - 10:32:07 AM »
Who's harness is it?
Does it just die all of a sudden or does it sputter and die...like a fuel issue?
« Reply #2 on: November 12, 2010 - 11:50:04 AM »
the pick up coil inside the dist can do this
the coil can be a problem as it warms also
« Reply #3 on: November 12, 2010 - 12:12:34 PM »
When it initally happened (down the street from my house) it sputtered and died but it did refire (with a little cranking).  Now that it's home in my garage, I could just be standing there watching it idle and all of a sudden  -  dead.  No warning.  But  it will re-fire immediately.  Wait 2 minutes and it will die again.
Harness is from Evanswiring.
Thank you.
« Reply #4 on: November 12, 2010 - 01:33:39 PM »
When it dies, check to see if you have any fuel left in the carb. Maybe fuel filter?
« Reply #5 on: November 12, 2010 - 01:38:44 PM »
Or is it flooding out?
« Reply #6 on: November 12, 2010 - 03:06:29 PM »
I can't imagine that this is a fuel problem because as soon as it dies, I lean inside and turn the key and it starts immediately.  I did have to think about that though...............
I'm thinking it's the harness.  Up to that point the car was fine.  I put the new engine harness in and now this issue is happening.  Tonight, I will check every connection (especially at the bulkhead).
Thanks to everyone.
« Reply #7 on: November 12, 2010 - 03:30:18 PM »
I've heard there have been problems with Evans harnesses before.  Connections havn't been crimped good enough.  Good luck!
Offline ShelbyDogg
« Reply #8 on: November 12, 2010 - 03:33:49 PM »
I would get a new wiring harness.
