Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Ignition key cylinder replacement ?
« previous
next »
Print
Pages: [
1
Author
Topic: Ignition key cylinder replacement ? (Read 1333 times)
rb70
Jr. Member
on:
November 12, 2010 - 06:03:35 PM »
Anybody got some tips on replacing the cylinders?
Manual says you need 2 tools - steering shaft removal tool and lock plate pin tool.
Where can I get these or is there someother way to remove the shaft and pin?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Ignition key cylinder replacement ?
Reply #1 on:
November 12, 2010 - 06:55:14 PM »
you will need a special puller to get the crush can off , you need snap ring pliers to get the lower housing off ,a simple pin punch will remove the roll pin , you will need to remove the plate over the lock tab to get at the hidden hole to hold the lock in
Logged
CUDA JAS
Resident
vroooooom!
Reply #2 on:
November 17, 2010 - 03:54:33 PM »
I did this for the first time over the summer...its not too bad.
You will need a sterring wheel / harmonic balancer puller (you will likley need to buy longer bolts seperatly) and snap ring pliers.
If you PM me your address I will emial you a very indepth article on how to dissassemle the column. Its from a member here and helped me a great deal!
Jason
Logged
74 'cuda 360/727
Just call me a gearhead!
rb70
Jr. Member
Reply #3 on:
November 20, 2010 - 02:12:44 PM »
I am down to the wheel lock mechanism and I do not see the roller pin. All I see is 4 indentions, so under which indention should the pin be?
Or should I just drill out the indentions and find it?
Also, do you have to take the column out of the car?
Last Edit: November 20, 2010 - 02:16:22 PM by rb70
Logged
rb70
Jr. Member
Reply #4 on:
November 20, 2010 - 05:49:20 PM »
Ok, for future use.
You have to take column off, you do not have to take off the steering lock wheel.
Also, do not lose the snap ring(as I did), I had to go to hardware store and buy a pack of them.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
November 20, 2010 - 11:58:39 PM »
there is a collar that slides over the roll pin above the steering lock plate
Logged
7samurai
Jr. Member
Reply #6 on:
December 12, 2010 - 04:42:21 PM »
If it's any help, I used a 2 bolt steering wheel/pulley remover which fit down in the crush can and it came off without any problem. I have the same question about the lock plate and would like the dissassembly details forwarded to me. the lock plate has me puzzled.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
December 12, 2010 - 06:59:06 PM »
there is a ring over the top of the roll pin through the plate , pry the ring up tap out the roll pin & the lock plate will slide off the shaft , below that there are 2 Phillips screws , remove them & the lever retainer plate will come off revealing the lock release pin
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
