Author Topic: Leaky trans help  (Read 834 times)
Offline CUDA JAS
  • vroooooom!
Leaky trans help
« on: November 12, 2010 - 09:20:33 PM »
MY trans works great, but leaks from multiple spots....pan, tail shaft, speedo gear, maybe more.
Is it possibel to fix these leaks with out rebuilding the trans (does not seem to need it) and without removing the trans from the car (don't really have the room).
Thansk,
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Katfish
  • 70 Challenger
Re: Leaky trans help
« Reply #1 on: November 12, 2010 - 09:59:04 PM »
Absolutely , I had 5 spots leaking:
Neutral safety switch gasket rotted
selector shaft seal
speedo cable
pivot pin
pan gasket
You can fix them all in the car.
« Last Edit: November 12, 2010 - 10:01:32 PM by Katfish »
« Reply #2 on: November 13, 2010 - 07:11:13 AM »
When I was chasing leaks I found that O'reilly has good selection/reference for seals
http://www.oreillyauto.com/site/c/search/Transmission+Seals/C0071/C0338.oap?keyword=transmission+seals&year=1973&make=Dodge&model=Challenger&vi=1078680&page=2&results=15&sortBy=1
Speedo/pinion gear is easy.
My main leak turned out be the NSS ...don't forget the dipstick tube
« Last Edit: November 13, 2010 - 07:13:40 AM by Bullitt- »
