Author Topic: speedometer cable  (Read 696 times)
Offline rb70
speedometer cable
« on: November 14, 2010 - 02:55:53 PM »
How do you get the cable back into the speedometer?
70 Cuda/auto and the cable came out easy and now I cannot get the cable back in, it seems to go in about half way and stops.
Re: speedometer cable
« Reply #1 on: November 14, 2010 - 07:01:33 PM »
There is a white tab on the outside you need to squeeze to put it on there. If you are already doing that, then maybe you need to rotate the cable a little to get it in there.
Offline rb70
« Reply #2 on: November 14, 2010 - 07:18:31 PM »
It goes in half way, but it is still about a 1/4" from being close enough to get the white tab in place.
Could the I have done anything to the cable, when I disconnected it?
« Last Edit: November 14, 2010 - 07:49:08 PM by rb70 »
Offline Aussie Challenger
« Reply #3 on: November 15, 2010 - 05:51:01 AM »
The speedo cable may have come out at the bottom end, try rotating the inner cable with your fingers as you apply a bit of pressure, then wiggle the outer cable slightly while holding pressure when trying to fit onto speedo head.   :2thumbs:
Offline rb70
« Reply #4 on: November 17, 2010 - 06:15:29 PM »
Give the man a cigar!!
