Author Topic: 323 posi  (Read 3975 times)
Offline dixiedog
323 posi
« on: November 15, 2010 - 09:41:42 AM »
Finally got my car on the road, 70 chally.  Drove it this week end, yahoo!  Couldn't stop to get gas without a crowd gathering.  One guy yells at his buddy " Hey you have got to come see this Charger" , I didn't say a word.  All in all it went great but I do have a problem with the rearend, it's whining/singing.  I had driven it with open headers but hadn't noticed until I had the exhaust put on it last week.  I drove it about a hundred miles over the week end but it looks like I am going to have to replace the center chunk on the rear end.  What would be the problem?  Just checking on my options.  Thanks, Danny
Offline nqkjw
Re: 323 posi
« Reply #1 on: November 15, 2010 - 11:04:02 AM »
More likely to be the mesh between the pinion and ring gear.
Proper adjustment/shimming MAY improve it but probably not if it's been run like that for a while.
Burnouts are cool but Traction is the Action
wagesofsin
Re: 323 posi
« Reply #2 on: November 15, 2010 - 11:29:39 AM »
this may sound lame , but have you checked the fluid level? and if its a suregrip , do you have the additive in there?
Offline dixiedog
Re: 323 posi
« Reply #3 on: November 15, 2010 - 04:00:48 PM »
yes I installed it, put the fluid in it myself and I put additive in as well.  I bought the center section off of a parts guy.  I am not going to worry about it right now but I am probably going to have to take it out and go through it.  I have to have the 727 adjusted, the guy that rebuilt it said to bring it back after I put it in and he would do that, goes through the gears to quick.  I may see if he will do it, he use to do alot of rearends.  But it was a blast getting to finally drive it.  I had actually forgotten what it was like to drive one.   :cooldancing:  Thanks Danny
Had it not been for this site I would never had been able to get this project completed.
Re: 323 posi
« Reply #4 on: November 15, 2010 - 04:18:07 PM »
Danny,
  Not to get off-topic, but sounds like your kick down linkage needs adjusted if the car shifts too fast. I know when I first bought my car, I swear it was in hi gear by 10 MPH.    :bricks1:
Offline dixiedog
Re: 323 posi
« Reply #5 on: November 15, 2010 - 07:31:42 PM »
Exactly, my car is in drive before I get to 10mph as well.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 323 posi
« Reply #6 on: November 15, 2010 - 07:59:55 PM »
In my old 5th ave, my 8 1/4 rear end was whining and I replaced the spider/differential gears and it fixed the problem....temporarily.  Sound came back though.  Not sure if aybe the issue was actually the ring and pinion or else because I didn't shim the differential gears when I installed them.  :bricks1:
Re: 323 posi
« Reply #7 on: November 17, 2010 - 03:23:27 AM »
you will need to install a new ring & pinion the bad news is I do not of anyone making 3.23 gear sets
Re: 323 posi
« Reply #8 on: November 17, 2010 - 09:41:36 AM »
As Chryco mentioned, not in 3.23, but other gear ratios are available.... time for a 3.55?  :dunno:
http://www.ringpinion.com/PartsList.aspx?SearchMode=Make&MakeID=1&ModelID=211&Side=Rear&DiffID=8&CatID=10
Offline nqkjw
Re: 323 posi
« Reply #9 on: November 18, 2010 - 07:19:18 AM »
Surely there'd be plenty of 2nd hand good 3.23s over there wouldn't there be?
Would have been very common OEM ratio?
I've got a couple over here!!!
Offline ChallengerHK
Re: 323 posi
« Reply #10 on: November 18, 2010 - 09:47:54 AM »
- Han Solo, Star Wars
Offline nqkjw
Re: 323 posi
« Reply #11 on: November 18, 2010 - 10:34:52 PM »
Offline dixiedog
Re: 323 posi
« Reply #12 on: November 22, 2010 - 11:52:31 AM »
I live about a hundred miles north of Knoxville.
Offline nqkjw
Re: 323 posi
« Reply #13 on: November 23, 2010 - 12:51:00 AM »
Mine comes from a Mike who runs a radiator shop in Knoxville.
Was 5 years ago.
Offline dixiedog
Re: 323 posi
« Reply #14 on: November 23, 2010 - 02:36:23 PM »
I bought my 3.23 stump from a local Mopar guy, but like someone said "there is a reason they were pulled to begin with".  May just go with a 3.55.  Thanks, Danny
