Author Topic: RMS vs XV front/rear suspension upgrades - what's better?  (Read 16851 times)
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
Re: RMS vs XV front/rear suspension upgrades - what's better?
« Reply #30 on: February 27, 2014 - 12:50:44 PM »
Their website is unresponsive to inquiries as well, I had heard on protouringmopar.com that they re selling off everything
yea this happend in the last 2 week, i was able to fill out and add to cart and now everything is out of stock. hopefully they are selling it off to someone who can produce it better.
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline jvike
  • Pro-Touring Cuda
« Reply #31 on: February 28, 2014 - 11:58:45 AM »
How much HP will that set up work with? How much is your car putting out right now? I do not think the top mount would hold up with hight HP. It might rip out of the body I would think a tube would work better than the sheet metal it is mounted to. Nice car is it a real AAR?
I'll have to check out the HP specs, but there are two versions of the LCA in the rear suspension. I have the narrow verison. My car probably puts out 300 hp at the crank. But I'm just guessing. I ripped my top mount, becouse I welded it in a little to low.. Stupid mistake. Had to grind it loose again and then the metal probably was a bit thin. So after I riped it I added a bigger reinforcemant plate and put a bolt and nut trough the whole floor/plate/mount sandwich to hold it together. Then I did lots of donuts and everything I could to brake it. :burnout:
Not a real AAR, G code Barracuda.  :cheers:
