Thanks for the quick replys. I will go disconnect the battery.
A bit more info. My last battery lasted 9 months. The voltmeter flickers with the blinkers, brake lights and any use of current. The lights also dim and get brighter. Something is wrong somewhere.
Last week I cleaned up the taillight wiring. It was a mess, held together with duct tape. I soldered and shrink tubed all the breaks and cleaned the contacts and replaced the bulbs. They now work fine. There is a mess under the dash. Cut wires and an aftermarket radio.
I will try the wiper motor, you know I turned the wipers on by mistake when I started the car in the dark and wanted to see if the dash lights were on as bright as possible.
