Crossed wires could be a problem. I straightened out the rear harness and cleaned the light sockets with Deoxit D5. I went out tonight and checked the lights. The rear pass side turn signal left light is full power, the right light is dimmer. I will replace the bulb and see if that makes a difference. The front works, but the front light has been replaced. Given everything else on the car it is a hack job. I will look into that.
Also, I have not replaced the alternator, so I am going to check that out to make sure it is still good as well as the voltage regulator.
