Author Topic: replacement rear quarter panels  (Read 7918 times)
Offline usraptr
Re: replacement rear quarter panels
« Reply #15 on: February 20, 2011 - 07:30:25 PM »
How bad is the rest of the Quarter Panel? Replacing the whole thing is a heck of a lot of work to take care of that hole.  :clueless:
 :iagree:  When you ask if the replacement quarters go all the way to the seam, do you mean the dutchman panel seam?  If so, yes, full quarters will go to the seam.  :2thumbs:
(Edited 8-1-17)
« Reply #16 on: February 20, 2011 - 09:52:30 PM »
If that hole has been like that for a long time; there's a good chance the trunk floor pan extensions will be rusty at the lower wheelwell behind the tire.
Offline rb70
« Reply #17 on: February 20, 2011 - 10:45:46 PM »
Swiss cheese comes to mind, big hole behind the wheel well and a couple of holes in front of the wheel well and one of above.
Offline Challenger III
« Reply #18 on: February 20, 2011 - 10:49:44 PM »
Oh boy! You're in for a real treat!  :grinyes:
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #19 on: February 22, 2011 - 08:25:11 PM »
The trunk weather strip is adhered to two metal pieces that weld to the quarter panels.  You will need to buy the trunk gutter pieces and weld them to the quarters and tail panel.  This will fix your problem.
You can find them in my catalog here.  Look on page 19 and you should find them.
http://www.ebodyproducts.com/files/EBP_Catalog_R1.pdf
Hope this helps!!!  Good luck!!
« Reply #20 on: February 22, 2011 - 09:22:48 PM »
No doubt!
It's a challenge if you never did it before.
But don't be scared. Be determined and do it yourself.
« Reply #21 on: February 22, 2011 - 10:29:19 PM »
No doubt!
Well said!  :cheers:
