Author Topic: Clear plastic sheet on inside of door sheet metal  (Read 778 times)
Offline femtnmax
« on: November 20, 2010 - 09:33:32 PM »
A question about the glue that bonds the clear plastic sheeting to the metal door frame.  The plastic sheeting is then covered by the inside plastic door skin.  The OEM glue, usually white in color that holds the plastic sheet in place stayed tacky forever, you could remove the plastic and reapply and it would stick.
Does anyone sell this "glue/putty", or what is everyone using to bond the plastic sheeting to the door sheet metal?
Phil
Offline the_engineers
Re: Clear plastic sheet on inside of door sheet metal
« Reply #1 on: November 20, 2010 - 09:49:33 PM »
Silicone
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline rallye73
  • Model cars for the big boys!!
« Reply #2 on: November 20, 2010 - 11:28:00 PM »
You might also try the 3M strip caulk.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
« Reply #3 on: November 21, 2010 - 12:05:48 AM »
3M caulking also known as dum dum
