Author Topic: 2003 mitsubishi montero oil in water  (Read 1443 times)
Offline BadJoey
« on: November 21, 2010 - 07:58:16 PM »
Any help out there ? My motero has oil in the radiator . No water in the oil yet . Has never over heated . Owned it from day 1 . Runs great . Any ideas all I can think of is head gasket , cracked head ?  :clueless:
Offline cudadave72
  • you motorboatin sob!!!
Re: 2003 mitsubishi montero oil in water
« Reply #1 on: November 21, 2010 - 08:54:11 PM »
As you mentioned it could be a head gasket, cracked head or a cracked cylinder wall. I had a truck once that had a crack cylinder wall and there was oil in the coolant and not vise versa. The truck also seemed to run fine too. I did notice that the coolant system was getting over pressurized and would blow coolant out the cap. This could be a hard problem to find until it gets worse. Good luck!
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline BadJoey
« Reply #2 on: November 21, 2010 - 10:23:31 PM »
Thanks Dave . My plan is to drain and flush then put a ceramic coating in the rad . Then drain and refill . I have heard great stories about this ceramic coating . Bad thing is seeing how the preasure is blowing into the cooling system instead of out , plus even after flushing I know oil will still be there . But hey it's worth a 40 or 50 dollar try compared to maybe thousands .
Offline BadJoey
« Reply #3 on: November 22, 2010 - 04:42:56 PM »
Maybe good news . I just left my buddy at the local auto parts . He does not think I have oil in the water .Reason being the oil would have to be under more presure than the water .The only places that happens is away from coolant areas ,bearings push rods and such . Once the oil reaches the top of the heads it free flows back to the oil pan . that is when the 2 would come in contact at which time the water would be under more presure thus putting water in the oil . Not the case . He said flush the system then see if it happens again , the anti freeze hasn't been touched in 110 thousand miles and could just be really crappy .
If it gets more oil in it he would bet it is most likely trans fulid . He hears of the radiator leaking trans fluid into the anti freeze a lot . New radiator is about $150.00 so my fingers are crossed . I have to wait for the rain to stop before doing anything . Although I have a 3 car garage I do not have a dry place to work on it if it is raining out . Too much junk or I mean collectibles .  :dunno:
