Author Topic: Question re: torque boxes and frame connectors  (Read 4052 times)
Offline ChallengerHK
« on: November 22, 2010 - 02:45:59 PM »
I'm assuming that, if I can only do one, I'll get more bang for te buck from subframe connectors than from torque boxes. Is this a good assumption?
- Han Solo, Star Wars
Re: Question re: torque boxes and frame connectors
« Reply #1 on: November 22, 2010 - 05:45:23 PM »
Hummm good question! Only thing I can say is the subframe connector I made attaches to part of the rear torque box?
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: November 22, 2010 - 07:47:36 PM »
i'd do both.  Yes you'll get a stiffer frame with the connectors, but the rear torque box helps the front spring hanger mount from twisting as well.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #3 on: November 22, 2010 - 08:25:27 PM »
Granted. But assuming that I'll be extremely lucky to raise the money to do only one, and that I'll have to sell parts to make that happen, and that I'll be lying on my back on what, if I'm lucky, will only be very cold ground and not snow to install them and I'm going to want to do that for as little time as I can get away with...subframe connectors or torque boxes?
« Reply #4 on: November 22, 2010 - 08:29:09 PM »
I'd buy the torque boxes first, them MAKE subframe conectors. I did, cost me $10!
Offline BIGSHCLUNK
« Reply #5 on: November 22, 2010 - 09:12:23 PM »
I'm with Brad $10 and your good to go!
« Last Edit: November 22, 2010 - 09:13:56 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: November 23, 2010 - 08:02:55 AM »
start with the rear boxes then. All they really came out of the factory with, then make your own frame ties.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #7 on: November 23, 2010 - 09:00:32 AM »
Never know anyone who's done a comparison. It isn't tough to do though. Maybe I'll dig up some instructions, post them up, and we can have members check for deflection between the two.
« Reply #8 on: November 23, 2010 - 09:03:00 AM »
 :iagree:  Great idea Dave! :2thumbs:
« Reply #9 on: November 23, 2010 - 09:15:37 AM »
That would be way cool.
Offline Aussie Challenger
« Reply #10 on: November 24, 2010 - 08:07:33 AM »
Keep us informed, I have seen where a person made both torque boxes as well as the sub frame connectors but if you are doing on your back the torque boxes would be harder to work with if trying to make yourself.
Offline aris_unlimited
  • Project in full swing
« Reply #11 on: November 24, 2010 - 08:11:42 AM »
I ended up getting the XV subframe connectors (pain in the rear to make them fit) and they said that all their test cars don't have the torque boxes, so they don't consider them really necessary. While I have problems with XV's work eithic and customer service, they seem to know their stuff when it comes to suspension and chassis stiffening.
Cuda is gone :(
74 satellite, daily driver/project now
« Reply #12 on: November 24, 2010 - 10:17:01 AM »
An advantage to torque boxes is that they tie the subframes into the rocker sills. The rockers are a very large structural member than runs the length of the passenger compartment and these pieces are much larger then sub frame connectors so they will tend to bend less.
However, one advantage to most sub-frame connectors is that they tie in or bisect the floor which then turns the floor pan into a giant shear plate, creating a larger structural member.
If you go way back in to the past, you'll notice most competition cars did not use the longitudal subframe connectors we are all familiar with, but instead used X members tieing all four corners of the cab together along with bisecting the floor and putting it in shear. The weld in aftermarket sub frame connectors we most familiar with were developed as a reasonably easy to install structural piece that would create the greatest amount of improvement for the least amount of cost and effort. That doesn't mean they produce the best amount of rigidity, just the best amount for the cost and effort. Torque boxes can be looked at in the same way only from an OEM manufacturers perspective. They are both bang for hte buck approaches.
« Reply #13 on: December 05, 2010 - 12:28:26 PM »
Here is a good in depth discussion about torsional rigidity along with ways to check.
http://www.pro-touring.com/showthread.php?55201-Torsional-rigidity-measuring-and-increasing
« Reply #14 on: December 05, 2010 - 03:03:12 PM »
Thanks
