Author Topic: Reuse quarter panels???  (Read 4034 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: November 23, 2010 - 12:07:42 PM »
Tommorrow is D day for the start of tearing the Cuda apart to begin a full restoration. At some point the quarter panels where replace with skins and were overlaped onto the remainder of the original panel. They are in perfect shape other than they were incorrectly installed (bondo cracks along the seams) so my idea was to take them off, trim the excess and butt weld them back to the car so they are seamless. Any thoughts? ???
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Re: Reuse quarter panels???
« Reply #1 on: November 23, 2010 - 12:20:58 PM »
Sounds like more work than just replacing quarter panels as a whole.   :2cents:
I did the center trunk floors in my car butt welding. Took forever. That was my first metal project. After that, I never did that again. I just replaced complete metal portions.
wagesofsin
« Reply #2 on: November 23, 2010 - 12:50:19 PM »
you have the right idea , strip all the filler , cleco the excess , and air saw in the center , stitch em on every 3 inches or so. rinse and repeat. will be waaaaaaay easier than doing a whole 1/4. take your time.
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: November 23, 2010 - 01:37:41 PM »
Agreed.   Just replace the complete quarter.
Offline cudadave72
« Reply #4 on: November 23, 2010 - 02:15:07 PM »
I guess my hope is to avoid spending 1200 dollars on sheet metal even if I spend more time on it.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: November 23, 2010 - 02:36:41 PM »
cleaner less labor intensive with just putting new FULL panels on. but its your project. if it is just the old seam your wanting to correct, then I agree with Wages. small welds at intervals dont over heat.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline cudadave72
« Reply #6 on: November 23, 2010 - 04:47:23 PM »
I guess the best thing to do is strip the panels down and see what I am working with. Like mopardave mentioned I'm looking to repair the seams correctly. It seem a shame that there is nothing else wrong with these skins other than being improperly installed from the get go.
wagesofsin
« Reply #7 on: November 23, 2010 - 05:54:26 PM »
i coulda swore i saw that somewhere..... :clueless:
that daves a real genius. at least he got it.  :2thumbs:  :smilielol:
« Last Edit: November 23, 2010 - 06:00:36 PM by wagesofsin »
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #8 on: November 23, 2010 - 06:00:28 PM »
My cuda was also done with skins and when I redo it again (soon I hope)I will spend the money and buy new full quarters,one pc trunk floor etc. and the end result will be much better.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline cudadave72
« Reply #9 on: November 23, 2010 - 08:42:47 PM »
Your my hero John!!! :2thumbs: :woohoo:
« Reply #10 on: November 23, 2010 - 08:55:17 PM »
First time I ever replaced a whole quarter panel on my car or any car for that matter. It was a bit of a wrestling match at first. If I had to do it again, I know it would be much easier and less hours to do from what I learned the first time.
Offline cudadave72
« Reply #11 on: December 04, 2010 - 09:13:35 AM »
Well I started stripping the right side quarter panel and found that the idiot that installed the skins layed it over parts of the original panel that still had rot in it. Luckly I started this project now because were the quarter meets the rocker was done incorrectly and the rocker (otherwise super solid) was starting to rot underneath the bad work. Good news is that I ground off the rust and it was still solid underneath. Now it looks like shes getting full panels.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #12 on: December 04, 2010 - 10:58:10 AM »
well if your needing full panels or another set of skins i have them on the shelf.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline elitecustombody
  • Supra collector
« Reply #13 on: December 04, 2010 - 11:51:40 PM »
So much for saving the quarter,lol.Yeah,it usually helps when you have the mud off the panels for a closer inspection.  I think you'd sleep much better after replacing full quarters and alot less work.
Stefan B
Elite Custom Body = AMD Sheetmetal & Glass at great prices !!
Don't do what's easy, do what's right!!
Offline Challenger III
« Reply #14 on: December 05, 2010 - 12:02:23 AM »
Keep a close eye out when you clean off the rust on your rockers. Even if there no holes, they might be thin. Here's mine (Inside the car). I'm replacing all of the pitted metal area even though the pits are not all the way through.
« Last Edit: December 05, 2010 - 12:03:59 AM by Challenger III »
Mike    Yakima, Washington
