Author Topic: PPG paint quote  (Read 10041 times)
PPG paint quote
« on: November 23, 2010 - 10:27:42 PM »
As some here may know, I'm planning on painting my car completely in PPG Deltron B-2 Glacial Blue, base coat/clear coat. Here's the quote I got today.
Are these prices inline? I think I need to increase to 2 gals of B/C?  Should I buy online these items if the price is significantly better than this? Who would you recommend?
Offline don340-4
Re: PPG paint quote
« Reply #1 on: November 23, 2010 - 11:45:06 PM »
  Topcat; Have you tried TCPGlobal.com they are in San Diego, best prices I have
  found.      :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline Cuda Cody
  • Vancouver, WA
Re: PPG paint quote
« Reply #2 on: November 23, 2010 - 11:57:12 PM »
Are you painting the inside and bottom of the car?  Engine bay too, right?  Are you planning on doing base / clear on everything or single stage on the bottom and inside of the car?
Re: PPG paint quote
« Reply #3 on: November 24, 2010 - 12:18:12 AM »
Its a metallic so its going B/C C/C everywhere.
Re: PPG paint quote
« Reply #4 on: November 24, 2010 - 12:27:08 AM »
that is 1/2 of what I paid for the PPG Base clear purple I used
Re: PPG paint quote
« Reply #5 on: November 24, 2010 - 12:41:57 AM »
Wsa it Deltron or Omni? Big difference in the two.
Offline torredcuda
  • Epping NH joined 11/23/03
Re: PPG paint quote
« Reply #6 on: November 24, 2010 - 09:14:27 AM »
Are you using the epoxy primer as a sealer?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Re: PPG paint quote
« Reply #7 on: November 24, 2010 - 09:19:47 AM »
Yes. Probably get 1 gallon of Featherfill prior to that also.
Offline elitecustombody
  • Supra collector
Re: PPG paint quote
« Reply #8 on: November 24, 2010 - 09:25:45 AM »
Instead of wasting money on another gallon of expensive basecoat,I'd spend that money on tintable sealer and have it nearly same color as the basecoat ,it is never a good idea to hose on alot of basecoat, and some colors will take more than 3 coats to get good coverage and hideout .Tintable sealer is more durable than basecoat and serves as a good tie-coat between your primer surfacer and the basecoat.
Another suggestion is to find a local jobber that sells Matrix ,you won't even pay half of what you'd pay for Deltron and it will have same or better outcome. Want to know why? Because I've been using it everyday for probably 15 years
Stefan B
Re: PPG paint quote
« Reply #9 on: November 24, 2010 - 09:46:37 AM »
I agree tinting the sealer. I asked that yesterday. Dude said PPG sealer can't be tinted. They sell a DP60LF which is a blue epoxy primer. I'm hearing its too dark for B-2 to use.
Then there's the Coating store.com for tinted primer. Tempted. But no known adhesion knowledge when used with PPG. I e-mailed them they didn't have an exact answer.
I need more information on Matrix. I'll need to make a trip down to Watsonville for that.
Offline bentpshrods
  • Almost there, Boise Id.
Re: PPG paint quote
« Reply #10 on: November 24, 2010 - 10:20:55 AM »
    I painted my car with PPG paints - deltron DBC  with DCU2021 clear about a year ago and the prices I paid here are pretty close to what you were quoted. I used the DP50lf epoxy as a seal coat .  For comparrison---gallon DBC   395.00,  gal  clear  210.00,   gal dp50  141.00.  Hardeners and reducers were about the same  price.  I painted the engine bay, jambs ,and trunk/wheel wells, inside front fenders. Did not paint the floor or anything underneath and used 1 1/2 gallons of paint. The painter said he was down to the last drop of paint to finish it so you should have some left with 2 gal.  I really like how it turned out with the PPG products.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: PPG paint quote
« Reply #11 on: November 24, 2010 - 10:34:27 AM »
 :clueless: You are the first shop that I have heard positive things about Matrix paint, I am honestly amazed that you have not had problems with it. All of the people I know in the paint industry refuse to use Matrix products due to numerous problems with the product (and believe me it is not the painters or the prep work as most of them primarily do high end show car work).
Most of the painters I know use PPG products. I would get a sealer. If you really want to make the color POP use a white sealer, if not, like stated you can tint it to use less base.
1996 Dodge Viper GTS Coupe
Offline Cuda Cody
  • Vancouver, WA
Re: PPG paint quote
« Reply #12 on: November 24, 2010 - 11:27:48 AM »
Stick to the PPG and you'll most likely need at least 2 gal.
Re: PPG paint quote
« Reply #13 on: November 24, 2010 - 11:57:48 AM »
I used Deltron , I would jave to look at the bill but it was over 250/ lt here
Re: PPG paint quote
« Reply #14 on: November 24, 2010 - 12:15:54 PM »
PM me any details you can on it would be appreciated.  :thumbsup:
