Author Topic: Cuda Door Top Trim Question - Does anyone know...  (Read 17220 times)
Offline 71cudajoe
    • 71 Cuda Restoration Project
« on: November 24, 2010 - 10:02:31 AM »
Does anyone know what the rule of thumb is for which Cudas/Barracudas came with door top trim. Was it simply a trim option that could be ordered in any year from 70 - 74? Or was it a standard that only came with certain models? I ask because I heard once that Barracuda models didn't offer this trim option and I'm wondering if that is true.
In researching photos on the Internet, I've noticed Cudas and Barracudas (in various years) both have door top trim, but I don't know if any of the cars I'm looking at are OEM correct. I've had two Barracudas myself. One had the studs and trim tabs (like shown in the photo below) for mounting the door top trim and the other didn't. I don't have fender tags for either car, so I couldn't compare to see if this was an option or not. Both of the cars are Barracudas (not Cuda models), so it made me curious.
David - '71 HEMI Cuda Retro-mod
FOR PICS VISIT www.71cuda.net
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Cuda Door Top Trim Question - Does anyone know...
« Reply #1 on: November 24, 2010 - 12:37:40 PM »
M31 is the code for the belt molding.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 71cudajoe
« Reply #2 on: November 24, 2010 - 02:13:59 PM »
Thanks, MoparDave. And this was an available option on any Barracuda and Cuda?
Offline acudanut
« Reply #3 on: November 24, 2010 - 02:29:45 PM »
What does belt molding have to do with door trim ? :dunno:
What is belt molding also ??
Offline 71cudajoe
« Reply #4 on: November 24, 2010 - 03:17:37 PM »
I didn't exactly make the connection with that either. I just assumed "belt molding" was the official term for door top molding.
« Reply #5 on: November 24, 2010 - 03:42:15 PM »
Yes guys,
  For some reason that escapes me, the top of the door trim and the mating trim for the bottom of the rear quarter windows is referred to as belt molding.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: November 24, 2010 - 05:34:58 PM »
Parts catalog refer to them as belt molding, the door trim top piece is the sweep/weatherstrip, and conflict back and for over the years in different catalogs.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline acudanut
« Reply #7 on: November 24, 2010 - 09:27:54 PM »
Belt molding to me means....maybe seat belt ?? :clueless:
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #8 on: November 25, 2010 - 06:48:56 AM »
Belt height.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Edison1970
« Reply #9 on: January 01, 2011 - 10:48:18 PM »
What is the correct way to remove the molding?  I don't want to damage the molding or the door.
Alaskan_TA
« Reply #10 on: January 02, 2011 - 12:37:15 AM »
Belt height.
Yep. Odd but true. Belt high if standing next to the car.
Your belt height may vary.
Offline jforest1
« Reply #11 on: January 02, 2011 - 06:49:24 AM »
I'm actually in my door right now putting on a callout.  I don't know but I can offer up some clues.
1.  Based on the picture above, looks like are screws holding it on.
2.  Pushing it to the front and back, it seems to slide a bit, but since it is concave, I don't think this is the way to remove it and I didn't try forcing it.
3.  Looking inside the door with the door panel off, there is a felt strip that the window slides up as you roll it up/down.  It is on the external side of the window and runs along the top of the door on in the internal side of the belt molding.  After a closer look, it is held on via 4-6 tiny screws.  If you take a few of those out, you may be able to see beyond it to the belt molding.  If you have to take it OFF completely to replace/add belt molding, this may be problematic, as the window appears to be in the way a bit (even fully rolled down).
Good luck and tell us how it goes, as I'd like to replace my driver side belt molding!
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Offline CarelianCuda
    • http://bot.fi/3gu
« Reply #12 on: January 02, 2011 - 08:47:08 AM »
M31 Belt Moldings was optional for 70-71 Barracudas at $13.60 - $13.45 price.
Std on 'Cuda & Gran Coupe (Except AAR & probably some very early production LA built 'Cudas?)
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
« Reply #13 on: January 02, 2011 - 11:30:06 AM »
My early production Hamtramck Cuda does not show the M31 option, at least on the fender tag....nor do the doors nor rear side glass show any indication of them ever having the molding strips mounted....
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Offline swede-cuda
« Reply #14 on: January 02, 2011 - 04:30:22 PM »
 :wave:i wonder what years they used studs versus screws to hold the clips for the molding? :clueless:
