Author Topic: Cuda Door Top Trim Question - Does anyone know...  (Read 17227 times)
Offline quapman
    • Auto-Grip on Facebook
Re: Cuda Door Top Trim Question - Does anyone know...
« Reply #15 on: January 02, 2011 - 06:41:58 PM »
All years used studs except possibly 70's. They had screws for the windshield moldings, so logic dictates that the belt molding clips might be screwed on, too. If you have screws, the trim was probably added or the door was changed.
What's the source for "all cudas" ? I know Gran Coupes came with belt moldings as std. eqipment, but have seen few BS cars with it.
Offline 67vertman
  • Member since 9-23-2005
« Reply #16 on: January 02, 2011 - 06:55:45 PM »
When i added it to my 70 barracuda the supplied hardware had one screw holding it to the front door frame.  I used the hole closest to the rear of the door as it was accessible without taking off the door panel.
The original molding I bought had the screw on the rear quarter panel molding.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #17 on: January 03, 2011 - 09:31:44 AM »
70 doors had an all plactis push pin style clip, 71-4 had the studs on the door and used a slide on clip.
pic one is the 70, pic 2 is the 71-4
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline CarelianCuda
    • http://bot.fi/3gu
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
« Reply #19 on: January 03, 2011 - 06:34:29 PM »
'70 (Except some early production as 71GTX just corrected)
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Barracuda0022.jpg
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Barracuda0007.jpg
http://www.hamtramck-historical.com/images/dealerships/SalesmansPocketGuides/1970/Pg%20032.jpg
'72 std on 'cuda, not available for Barracuda:
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1972/72_Barracuda_20.jpg
Not to be taken for gospel or the end all/be all....I'm just going off of what my fender tag says....  :thumbsup:
EN1
M88 N41 N42 R11 Y5X Y05
FY1 C16 C55 J45 M21 M25
FY1 H6X9 000 820 017578
E63 D21 BS23 N0B1017XX
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Offline quapman
« Reply #20 on: January 03, 2011 - 07:08:53 PM »
Thanks for the links. My latest guess is that a lot of these got permanantly removed by their owners who didn't like scorched arms on a hot, sunny day!
Offline lahatte
« Reply #21 on: January 03, 2011 - 07:24:47 PM »
Weird.  That first link that CarelianCuda posted claims the 383 cuda had a "cuda" insignia on the glove box door.  There ain't no cuda insignia on the glove box door??
Offline CHL2T
  • Handle it, man!
« Reply #22 on: January 03, 2011 - 07:36:14 PM »
My 73 Cuda has belt molding, although I am missing the passenger door piece as the door has been replaced.
If anyone has one floating around, lemme know :2thumbs:
Offline jforest1
« Reply #23 on: January 05, 2011 - 05:45:26 AM »
Ditto on my '73 Cuda, except what I'm looking for is the driver-side, which has a big ding in it.
So pardon, I'm a  :newbie:, but it looks by those attachments that mopardave posted, the removal technique for the belt molding is to press, slide (forward/backward?), then lift?  A little scared of forcing it...
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
    • http://bot.fi/3gu
« Reply #24 on: January 05, 2011 - 12:53:55 PM »
Plans looks changed, also notice that '71-74 slap-stick on the '70 Dealership Data Book:
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Barracuda0019.jpg
Offline 67vertman
« Reply #25 on: January 05, 2011 - 11:13:59 PM »
JF
If you look closely, they have four slots in the bottom of the attachment that push in to the holes in the door. so, when pushed into the holes they collapse some and then expand.  To get them off, use a scraper or trim removal tool, slide it under the trim and twist it to a 45% angle ant they will pop out of the hole.  Be prepared to break some, as they are 40 years old and brittle.
Offline RB2929
« Reply #26 on: January 06, 2011 - 08:39:54 AM »
Mopar Dave-
The Roseville web site does not have a price tag associated with the 71-74 Cuda Door Top molding Retainer Kit
[1000020].
Ron
Offline mopardave
  • Sponsor
    • rosevillemoparts
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline tommyg29
« Reply #28 on: February 02, 2011 - 08:11:13 PM »
to confirm then, for a 71,
remove by removing the one nut on the end, then prying up and twisting carefully on the trim, I guess starting on one end, and be prepared to buy the $40 kit. :bigsmile:
What is the trim strip made of, and can minor pitting and scratches be removed by polishing?
Thanks.
Offline Killer_Mopar
« Reply #29 on: February 02, 2011 - 09:48:58 PM »
I imagine its like the challenger one and made of stainless, which will polish up no problem....what does the pitting look like?
